Xserve Raid 2.18TB as Storage
Anyone use Apple Xserve Raid as the main Storage? We are trying to install a Xserve Raid 2.18T to use with our current Pro Tools HD|3. But we keep get DAE Error -9131. We can not record any thing into the Raid. Systems includes. Apple G4/867 DP 1G RAM / Mac OSX 10.39 Pro Tools HD /w Pro Tools 6.4 / 6.7 / 6.9 Apple Xserve Raid 2.18T dirct connect to G4 192 I/O Audio Interface Also, I would like to know is there any body using Apple Xsan solution with their Pro Tools Studio? Any sucessful story?:) Thanks, Allen |
Re: Xserve Raid 2.18TB as Storage
I'm not sure about this, but I think Pro Tools will not write to (or read from) a RAID. And I don't think it's possible, using Apple's software, to set the XRAID up as JBOD (just a bunch of disks) individually. I called Apple about JBOD and they said no, but I've read other places that it may be possible.
It is not just a simple as just plugging in the fibre and mounting a volume.
Do you have more than 1 cpu accessing a volume. It needs to RAID5 not 1 or 0. whats the file system format? ( should be HFS+ ) and not anything else etc........... on and on I have used fibre, RAID volumes for years and have nothing bad happen with this all is good.
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
We have a raid, two digidrives raided into one. Protools can read/write just fine.
ATTO scsi. |
It's really a shame, especially when Sonic Solutions was doing this 15 years ago with MediaNet! Our Sonic systems could access networked drives with two or more editors accessing the same file at the same time. Oddly enough, any of our two-track editors, i.e. Peak, Spark, DSP Quattro, can record/play from the server, so it's definately a Digi issue.
Eric Seaberg San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
A fibre RAID volume will not be seen as networked !
It is a local volume. Even in a fabric environment it will still work ! It will necessitate volume management software such as Fibrejet if you want to use volumes in a network. All the Fibre networked volumes will be seen by the CPU as local. After the RAID Controller chunks out the Volumes you can format the volume as if it was a unformatted disk ( HFS+ ) and IT WILL work for PT I've been doing it for years.. If in LA area I will be happy to make a service call....
Yes. The Fibre channel Raid will be treat as a local disk. It works fine with my G5/1.8DP and Pro Tools HD. But it jsut won't woth with G4/867 DP?
Any idea? Thanks, Allen |
Problem with ProTools and Xserve RAID | OysteinHalvorsen | Storage Subsystems | 0 | 12-23-2004 06:01 AM |
Pro Tools TDM with Xserve RAID | paraprod | Pro Tools TDM Systems (Mac) | 11 | 11-05-2004 09:09 AM |
Mac Xserve Raid | Daniel Mendez | Storage Subsystems | 0 | 05-01-2004 01:10 AM |
PT6 and Apples Xserve RAID | houser | Post - Surround - Video | 0 | 07-10-2003 03:07 PM |
Xserve RAID as storage for ProTools? | Matts | Storage Subsystems | 4 | 05-19-2003 07:33 PM |
