Old 10-02-2002, 03:37 PM
freakofnature freakofnature is offline
Default RTAS softsynths on windows ?
can anyone tell me if there are already rtas softsynths available for the DIGI001 on windows ?
and if so ,do you need WINXP or is 98SE ok ?
Old 10-02-2002, 03:39 PM
Mark_Knecht Mark_Knecht is offline
Default Re: RTAS softsynths on windows ?
SampleTank is the only one released. You must use Win XP/5.3.1 (or possibly 5.3.2 with the 002 if Dr. Phil says it works...)
Cheers,
Mark
<font size="2" face="Verdana, Arial">
Old 10-02-2002, 03:44 PM
thx for quick reply ! so it doesn't work for the DIGI 001 ? is digidesign going to do something about it ? or do we all need a 002 ? ;-)
Old 10-02-2002, 03:48 PM
Roy Howell Roy Howell is offline
Hi freakofnature (cool name),
Yes, it works with the 001. I'm using it with ME and 5.1. [img]images/icons/wink.gif[/img]
rh music
Old 10-02-2002, 03:53 PM
Bastiaan Bastiaan is offline
Mark,
Sampletank runs fine on a digi001/ptle 5.1/win98 system. I think it should also run on ptle 5.0, because it runs on ptfree.....and that's basically ptle 5.0.
Although sampletank is the only one available, there's also a good side to it. They offer a free version, so you can check out how it works. And i say it works pretty well. The free version is limited, so it can only use the special "free" sounds.
Go take a look at www.sampletank.com (although right now its of the air...)
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 10-02-2002, 04:29 PM
Phil O'Keefe Phil O'Keefe is offline
Both Sampletank and Pro 52 Digi Editions work great with the XP / Digi 002 combo.
There is a documented bug with the NI Pro 52 though - you get a nasty digital noise burst if you put a reverb on the same track as the Pro 52. If you use an aux bus for the verb, it's a non-issue. There's a d/l on the NI site that fixes the problem.
Phil O'Keefe
Old 10-02-2002, 04:41 PM
How is the Pro 52?
rh music
Old 10-02-2002, 04:56 PM
Sweet! [img]images/icons/cool.gif[/img]
Phil O'Keefe
Old 10-02-2002, 06:33 PM
Thanks Phil...I must have it now... [img]images/icons/grin.gif[/img]
rh music
Older RTAS softsynths Gothboy Virtual Instruments 1 07-29-2006 04:53 AM
RTAS RMX and other softsynths crashes eljodon Pro Tools TDM Systems (Mac) 17 07-22-2005 08:58 PM
RTAS SoftSynths darkglass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-28-2004 02:42 PM
RTAS Instruments for PT LE on Windows Mark Holloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-04-2003 07:10 PM
RTAS Softsynths??? who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-22-2002 01:36 AM
