Old 12-23-2001, 03:12 PM
davidpakman davidpakman is offline
Default Re: Disable MIDI Program change??
Thank you to everyone who posted comments.
In short, I COULD tell my XV3080 to ignore program changes, but then everytime I open a new PT session, I would have to manually set every program change. Or I could send all the info once, then turn off program change messages.
The point of all this is that I shouldn't have to. Digi should add a setting allowing program change to be sent ONCE...perhaps at the opening of the session, but not everytime it plays.
Thanks,
David
New Mac Pro (nMP) Trash Can 6 core 3.5 GHz 16GB RAM
Mac OS X 10.10.2
PT 11 HD 11.3.1
Sonnet Echo Express III-R
Pro Tools HDX
2 External 7200 RPM eSATA drives in Thunderbolt OWC Enclosure
Old 10-12-2019, 10:13 AM
Firechild Firechild is offline
Any news on this one?
Pro Tools 10.3.10.
I am using Program Change to change programs on a Bricasti M7 but it is annoying it sends Program Change everytime you hit play...better only on bar 1. Is it still no way to disable program change for every play command?
EDIT: In my case I could just use the Mute button on the channelstrip...after I had sent the initial program change to match the song.
HD3 PCIe, HD I/O , HD10.3.10, Mac Pro 6 core , 24 GB RAM , GTX285 , 10.8.5 , UAD-2 Quad Satellite , ATC SCM25A Pro with ADAM Sub 12.
Program change via MIDI on PT7 JSPurcell Tips & Tricks 1 09-13-2010 12:19 AM
problem with midi program change Riccardo Corbari Pro Tools TDM Systems (Mac) 9 02-22-2006 10:06 AM
midi program change porkipine MIDI 3 05-14-2005 05:52 AM
Midi Program Change Bug? Nocturnal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-28-2002 06:54 PM
Midi program change on the fly GaryGarris Pro Tools TDM Systems (Mac) 5 11-16-2000 11:20 AM
