  #21
Old 01-11-2020, 05:38 PM
Lynn Gräber Lynn Gräber is offline
Default Re: fader automation stops during pass
Gosh, this is by far the most annoying issue so far. I can't do any automation passes without it dropping out.
  #22
Old 01-13-2020, 05:13 AM
Cheesehead Cheesehead is offline
Wah!
This is a massive dealbreaker..
Dipping m&e's and long music tracks is a large part of what I use a surface for and I've just ordered one.
Please say this will be fixed soon.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
  #23
Old 01-14-2020, 11:42 AM
[email protected] vh@umbodid.is is offline
Originally Posted by robingshore View Post
I had something similar happen a few times today with my S1. It seems to happen if I'm continuously touching the same fader for an extended period. After about a minute it would stop acknowledging the touch and I could feel the fader's motor fighting against me. If I let go after that and grabbed the fader again it would give me back control.
It was happening in both touch and latch modes. If I was in touch mode it would just stop writing, and if I was in latch it would keep writing, but the fader would stay latched at the level it thought I had released it.
I have a customer reporting this same behaviour today.
  #24
Old 01-14-2020, 04:46 PM
EddieJones's Avatar
Sorry about this. We do see the issue here and are working on finding out what is causing it, I'll post once we know what it is.
  #25
Old 01-15-2020, 12:55 AM
Ale Ale is offline
Hi
I started to use my command 8 in parallel to get my volumes right.
Bad when my client sits behind me and every 47 seconds the show stops. The beta testers should have invested more than 47 seconds in testing
Just kidding
Anyway I love s1 and the iPad Control
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
  #26
Old 01-22-2020, 01:14 AM
Clemens Becker Clemens Becker is offline
Same problem here. Loosing automation with my mac pro 5.1 Setup ( 2 Avid S1 and a Dock connected ) after 54 seconds. just tested it on an iMac, loosing automation after 47seconds. While the Dock Fader is running fine.
  #27
Old 01-22-2020, 10:30 AM
EddieJones's Avatar
Sorry about this, We are still digging into the cause of this, it is proving hard but we are getting somewhere and will hopefully have an answer for you next week.
  #28
Old 01-28-2020, 08:18 PM
cunninghamaudio cunninghamaudio is offline
Any updates on this issue. I'm having the same thing. Touching a fader on the S1 times out after 50 seconds. I'm running the latest firmware and version of Eucon. Also have a dock on the same setup that is working just fine.
  #29
Old 01-28-2020, 09:05 PM
Neale Eckstein's Avatar
Neale Eckstein Neale Eckstein is offline
They are aware of it. Hopefully there be a firmware update soon.
  #30
Old 01-29-2020, 09:44 AM
EddieJones's Avatar
Default Re: No Write mode from S1
Originally Posted by Dror520 View Post
Hey all,
I hope I'm not doing anything really dumb, but when I use the Rec (A) button on the S1 to switch between the different automation modes I only get read, touch, latch and off. I don't have write. I have to use the mouse to switch it to write.
This is intentional as its very dangerous cycling through modes and dropping into write automatically
AUTOMATION TO DENSE then stops..... I have no automation Weird Audio Pro Tools TDM Systems (Mac) 1 12-07-2012 05:50 AM
Low/High Pass Filter Automation Help Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-08-2010 09:23 AM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2007 05:14 AM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2007 08:21 AM
HOWTO, audio file automation during record pass JFreak Pro Tools TDM Systems (Mac) 1 01-15-2007 09:00 AM
