Factory Bundle 8.0 Upgrade Offer ... Compatibility with LE 7.1?
I still have the Digi 002 original Factory Bundle (i.e. containing only two Moogerfooger plugs: Analog Delay & Ring Modulator) installed running on LE 7.1CS10 on PPC. Now I've just received from Digi an email offer for a Factory Bundle upgrade to v8.0, but when researching I sadly found conflicting compatibility information on the Digi Website:
The Plugin Compatibility Grid on http://www.digidesign.com/index.cfm?...n=news_details says that for LE 7.1, the minimum BF plugin version is 7.3 for Mac... so "minimum" should include v8.0, right? At least even the Classic Compressors v8 are also listed under PT 7.1 - 7.4. But then the download section on http://www.digidesign.com/index.cfm?navid=54&itemid=24497 says that the FB v8.0 installer is compatible only with PT 7.3 - 8.0 !? So can anyone please tell me which installer I'd need with LE 7.1 which will add at least the Moogerfooger Phaser and Lowpass? At any rate it looks that the FB 8.0 licenses on the iLok would be backwards compatible with the FB 7.x installers, right? Thanks a lot in advance for any enlightening hints!
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder |
Re: Factory Bundle 8.0 Upgrade Offer ... Compatibility with LE 7.1?
*bump* ... noone else in the same situation?
$30 Factory Bundle Upgrade? | ejwells | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-24-2009 12:45 PM |
How do i upgrade Factory Bundle to V.8??? | sureno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 12-27-2008 08:45 AM |
Factory Bundle Compatibility with PT7 | JCBigler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-20-2005 01:54 PM |
Factory Bundle upgrade | Eugene shuford4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-25-2004 05:22 AM |
Upgrade to Factory Bundle? | xx1messxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-21-2004 12:55 PM |
