how do you copy plug in settings
is there a way to copy plugin settings
I want to automate just short parts of a guitar track with different effects at different points in the track? |
Re: how do you copy plug in settings
command-shift-c and command-shift-v to copy settings between open windows of the same plugin type.
to automate a plugin, click the automation button in the plugin window, then you can choose what ever parameters you select there in the track view popup menu on the arrange page. Option dragging a plugin block (with playback stopped) allows you to copy plugins to other tracks/slots. hope this helps, Tom |
There is also the option to "copy,paste.cut..etc.." in the little pop up on the plug in itself when the plug window is open.
Question about plug-in copy settings | kierkegaard | Pro Tools 10 | 1 | 05-01-2013 01:37 PM |
Copy plug-in settings to audiosuit | tokolosh | Post - Surround - Video | 11 | 10-12-2009 03:42 AM |
Melodyne plug copy settings from one harmony to another? | crizdee | Pro Tools TDM Systems (Mac) | 7 | 04-15-2009 10:09 AM |
How to copy Plug In Settings from one computer to another? | christopherlennon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-11-2009 10:37 AM |
How Do I Copy Plug-In Settings to a Different Trac | morepiepop | Pro Tools TDM Systems (Win) | 2 | 11-20-2003 11:36 AM |
