Old 01-27-2011, 11:28 AM
Raoul23 Raoul23 is offline
Question Best way to copy settings etc
I've recorded a band which laid down 5 tracks and I've been working hard on one track and got it just how they want it, what's the best way to apply all the settings, pluggings and routing to the other 4 tracks
Cheers
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-27-2011, 12:13 PM
DontLetMeDrown DontLetMeDrown is offline
Default Re: Best way to copy settings etc
Search the reference manual for "Import Session Data"
Old 01-27-2011, 12:25 PM
Ok will do
Raoul Crane
Old 01-27-2011, 01:15 PM
Mount Royal Mount Royal is offline
What you want is to Import Session Data to your new black session, point to the session that contains the work you have done and want to replicate, and enter the Import dialog window. You will want to import tracks as New Tracks, and check many but not all of the items in the drop-down that pertain to bussing, plugs, possibly sends. Rarely, if ever, will you want to import automation, audio regions, markers, tempo maps, and other listed items will will not be generalizable across you band's 5 songs.
As a mild annoyance, track colors do not import.
Import Session Data is very powerful indeed, and has become my substitute for Session Templates.
Good luck,
John Caldwell
Pro Tools 2018.4
HDX, 192 and Lucid I/O
5,1 MacPro 12 Core; OSX 10.12.6
Old 01-27-2011, 01:43 PM
Thanks john that's a great help u have just saved me a load of time
thanks again
Raoul Crane
Old 01-27-2011, 01:45 PM
Sure. So will this feature save you loads of time. Just be sure you pay attention to the items you are, and are not, importing.
John-
Pro Tools 2018.4
Old 01-29-2011, 02:00 AM
suicune suicune is offline
Just a quick piece of advice on this one - I always keep my blank session template on a drive marked as transfer only in workspace, this way it never screws up the disk allocation even if you import everything apart from the main playlist.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 01-29-2011, 02:18 AM
crizdee's Avatar
crizdee crizdee is offline
another approach still using import session data which i prefer...
Once you've mixed the first song you can save this as a template!!
then open the template when you do the next songs then import the tracks into the template. (when you open a template it will first ask you to save it with a new name, which will be your next song etc)
when import data into the template all you need to import is the regions and the tempo map and locators, so un-select everything else unless you need them.
i save a different template after each mix! so if one sounds better i can recall that one etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-29-2011, 03:36 AM
AxeDye AxeDye is offline
Also its either control+click or alt+click but one of those will let you drag the plugis to another track leaving the original in place. I recommend mixing each track different as different sounds need different settings and when applying new settings its good to zero things out. Thats my preference not like some mixing law.
Old 01-29-2011, 07:16 AM
BaileyBass BaileyBass is offline
That makes a lot of sense in most circumstances... but when it is a band, same instrumentation, tracked over a period of days, without changing setup, crizdees method sure does save a lot of time. Then you can tweek it to fit whatever else you have tweeked.
different strokes for different folks..SB
[IMG] code is Off
5.1 pan pre-sets or cut and copy pan settings? amptbuddy Post - Surround - Video 7 06-24-2010 07:47 PM
Copy channel settings, please help me!!!!!!! bad_ben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2008 11:08 AM
Copy channel settings, please help me!!!!!!! bad_ben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-11-2008 04:24 AM
copy mix settings jpbears1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-25-2007 01:06 PM
how do you copy plug in settings surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-15-2001 07:52 PM
