Rotary encoder resolution
Hi All!
Here's my question. I'm looking at moving from ProControl to a D-Command. One of my main issues with the PC is the fact that I am ALWAYS holding down the apple key to get a finer resolution on the encoder while tweaking an eq. Without it, there's just too wide a jump in between settings. Is this going to be an issue with the D-Command, or can I turn a knob and have some nice, fine control over parameters? For example, I use the SSL E-Channel 99% of the time. Without the apple key, the finest resolution on the gain pots is 1db! Frequency and Q controls aren't a whole lot better in the way they jump around. I just want finesse. Can I have it with D-Command? Thanks for all your insights, whoever may respond. Rob Burrell aka mixboy |
Re: Rotary encoder resolution
You've got a few options for the rotary encoder resolution and indeed a fine resolution. I prefer normal resolution + apple key (if needed)
From the manual: "The Rotary Encoder mode affects responsiveness of rotary en- coder knobs. Fixed mode is at normal resolution. The velocity modes set different rates of encoder acceleration. In Fine mode, response is fixed and at fine resolution." Cheers, Bart
www.highlakehill.be |
Thanks Bart!
That's the kind of info I was looking for. peace Rob Burrell aka mixboy |
Command8 rotary resolution? | StachO | ProControl, Control|24, Command|8 | 10 | 01-05-2009 12:23 PM |
rotary encoder not working | tomcat | ICON & C|24 | 2 | 01-07-2007 02:14 PM |
Trim on ICON - doesn't map to rotary encoder? | GMitchell | ICON & C|24 | 0 | 09-12-2005 09:53 AM |
DAE 6.7b Rotary Encoder Performance Update | Avid | ICON & C|24 | 0 | 11-06-2004 09:34 PM |
dead rotary encoder. any tips on replacing? | tomcat | ProControl, Control|24, Command|8 | 1 | 08-06-2003 05:30 AM |
