Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 11-28-2020, 10:55 AM
Emcha_audio's Avatar
Default Re: Pro Tools Carbon Laptop Fan Noise
Originally Posted by Chris August View Post
Just got my new Pro Tools Carbon interface and this thing is incredible. Only problem I'm having is once I open a session I'm noticing my laptop fan running all the time at a higher level than usual. Even when the session is blank with nothing in it. I'm wondering if it has anything to do with the AVB setup. I've searched around and haven't seen anyone else saying they are having the same problem so I figured I'd post here and see if anyone has heard of or experienced this.
Also, before my Carbon I had a UA Apollo X8 and was using the same version of PT and everything was fine. The fans only started running more once I got this new interface.
Thanks!
Chris
I'm hoping you have done so before, but have you checked the compatibility for your Apple product with Carbon itself?
Manny.
Wave-T.com
Old 11-28-2020, 03:19 PM
Chris August Chris August is offline
So just another update for everyone... Yes I have checked and my laptop is compatible. I'm using a maxed out 2019 16" MacBook Pro and all the software is compatible with what Avid is looking for.
After many tests and eliminating certain things, there are 2 things sticking out...
Like I originally said, in the activity monitor coreaudiod has (not responding) next to it. Also, it triples in the CPU usage once I plug in the Carbon. I can plug in an Apollo or just use the built in sound card and it stays down. Just by plugging in the Carbon it goes up to around 15%. Even when I have my sound set to the internal speakers. Again, just by plugging in the Carbon, the coreaudiod will change to "not responding" and triple in CPU usage.
The other thing I've noticed now is that once you plug the Carbon in the kernel_task goes up really high. I know that has to do with the fan. The question is why is the Carbon making it go up so much. Right when you plug in the Carbon it goes up to 30% and the fan on my laptop starts running. This is what I would guess is the real culprit.
The problem is there is no way for me to fix that. I'm mainly wondering is this something Avid will fix with some sort of update and if that's even possible. As good as this interface sounds, the loudness of my laptop fans running would make me return it and go back to Apollo. Obviously, it's brand new and will take a little bit to get dialed in...which I'm good with that. I would just hate it if this is something that won't change even with updates.
Thanks!
Chris
Old 11-28-2020, 06:58 PM
Also, I decided to run a CPU temp check and see if it actually went up and it did. Without Carbon plugged in my CPU avg was 125 degrees F. After I plugged it in in would average 180 degrees F and the fans would start. Note, this is with nothing else running or even plugged into my laptop. I'm currently updating Pro Tools on a different laptop to see if the same problem occurs.
Old 11-28-2020, 09:52 PM
I had written another reply on here, but it's not showing up.
Wanted to add another problem with this... now I can't even change my I/O. It keeps telling me there is a new output that isn't assigned yet...which isn't true. Which now means I can't edit the I/O at all. I can't even set it back to default because it keeps giving that message and won't let me hit okay.
This is starting to feel like they released this before it was ready. At least for me anyway.
Old 11-29-2020, 08:43 AM
Default PT Ultimate I/O Problem
I have the new Carbon hooked up and the thing sounds incredible. I've run into a couple problems. One is it causes your computer processor to immediately heat up and starts running the computer fans. I'm hoping they will update and fix that.
My other problem has to do with the I/O. I opened up the I/O settings in PT and as I went to hit okay and close it I kept getting this message: “You haven’t assigned outputs for a new output path. Please assign outputs to it, or delete the path.” The problem is there aren't any new output paths. I've tried deleting all paths and hitting default on each tab, but that doesn't work. For some reason it's just hung up somehow. I also tried starting a new session and using a new stereo template, but it still doesn't work. The problem is now I can't make any changes to the I/O at all. Rename something...remove things I don't want to see in PT...etc..
Is there any way to do some sort of reset to the I/O other than the delete paths then hit default option?
If my option is to reinstall PT will I have to backup all my presets somewhere?
Thanks for the help!
Chris
  #16
Old 11-29-2020, 11:50 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT Ultimate I/O Problem
Hi, Not really sure what's going on, but have you tried hitting Default on the Bus tab of I/O setup?
The presets are located in Documents/Pro Tools - you may not have to back them up if you reinstall Pro Tools, but it's always a good idea to!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
  #17
Old 11-29-2020, 02:06 PM
Yes, I've hit default on each Tab. Nothing works. I wish there was just a way for me to erase whatever PT has of the Carbon and start over. Between it heating up my processor and now this I/O, I currently have a $4000 unusable piece of gear. I had to plug my Apollo back in just to get some work done.
I appreciate any help on here! Thanks!
Chris
  #18
Old 11-29-2020, 03:28 PM
XJENSEN XJENSEN is offline
Wish I could help. I see/hear a lot of these problems popping up. Avid better start properly testing their stuff before releasing it to public.
  #19
Old 11-30-2020, 06:39 AM
AdamScriv AdamScriv is offline
Might be a long shot but you could try deleting the .pio files from the preferences folder?
Just in case you don't know where they are:
https://www.sweetwater.com/sweetcare...s-preferences/
  #20
Old 11-30-2020, 08:17 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Chris, do you have a case logged with support yet? If so, please let me know the case number.
Of not, please log one and let me know what it is.
Thanks...
mark
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Static Noise with Pro Tools LE and laptop jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2007 10:43 PM
