Hello Guys,
I have read all around the net about people having the same problem as mine, the spinning ball that won't stop whereas you can't force quit an application and the music still plays in the background ... bottom line: the mac freezed ! and usually nothing would make it work again other than the power button ... However, I found a little fix which is whenever I am faced with this issue, if I unplug then replug my apple thunderbolt display then the mac unfreezes and I loose nothing of my work and works like a charm ... Anyone faced this ?? This is a turnaround but I would definitely fancy a permanent solution .... Anyone has got an answer for this or faced this ?? Could it be a hardware or software problem ?? Best
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz macOS 11.2.3 Pro Tools 2021.3 Logic Pro X Reason 11 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS http://www.youtube.com/becharasaliba |
DJ:
Once again this sounds like you may have Thunderbolt routing problems. I know in threads passed I mentioned that you may want to try different routing chains to see what works. Have you done that then and have you tried that with this problem? It's almost like there's something systemic going on with your setup that may well be Thunderbolt chain issues (that's assuming your Thunderbolt ports themselves are okay). |
I am still trying musicman ... its a maze ... i have my apple thunderbolt display to which is hooked 3 usb devices and 1 thunderbolt hard drive and I have the thunderbolt sound card hooked to another thunderbolt port ... so basically two thunderbolt ports on my mac pro with 6 total ports .. any ideas ? the best ports to hook it up to ?
![]() Quote:
I wish thunderbolt was never made man ... USB 3.0 is so fast when you plug USB 3.0 SSDs and hassle free ... not to mention that the thunderbolt ports on the mac are easily detachable if u move the cable a little bit the cable will be out of the port easily ...
Crap ....
![]() Quote:
not detaching themselves .... but they can be loose ... unlike USB ports
Never had that happen in either case. Makes a good case for cabling things together which adds security for the connections.
I heard the new mac pro will have additional usb ports :)
Mac Pro Late 2013 and GPU Freezes | Becharax | General Discussion | 42 | 11-30-2015 05:42 AM |
Anyone using the Late 2013 Quad-Core Mac Pro? | Jcalla | macOS | 18 | 08-22-2015 02:07 PM |
PT 11 and Late 2013 MacBook Pro 15.4 Ret' | garymmadison | macOS | 6 | 12-16-2014 05:29 PM |
Cracking sound with late-2013 MBP | Undertones | macOS | 9 | 11-11-2013 09:59 AM |
PT 11 - Freeze/Unfreeze/Freeze | mbahnmil | Pro Tools 11 | 4 | 09-10-2013 06:57 PM |
