Old 11-15-2013, 12:45 PM
Soundburst Soundburst is offline
Default Shortcut to change grabber type in Smart Tool?
Hey everyone,
Just wondering if there's a quick way to change the grabber type without knocking off the Smart Tool?
I usually edit with the smart tool and the grabber in Time Mode.
But sometimes I quickly want to change that to separation, or object mode. I'm using a stylus so don't have a right click easy to hand, and ctrl+clicking on the hand knocks off the smart tool . . .and when you enable the smart tool it automatically knocks whatever grabber tool you'd selected back to the standard time mode!
Any ideas?
Old 11-15-2013, 01:22 PM
CraveMac CraveMac is offline
Default Re: Shortcut to change grabber type in Smart Tool?
The F6 to F8 buttons select those functions individually.
If you need to go back to the smart to press F6+F7 simultaneously.
Thanks!!
Hope that helps..
Old 11-16-2013, 02:59 AM
joachim's Avatar
joachim joachim is offline
That won`t help.
As F8 , F8 , F8 , F7+F8 (or F6+F7 , or Esc) will revert the grabber in object mode back to smart tool with grabber in time mode.
And it is not a "quick way".
No idea about a solution.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 11-16-2013, 04:39 AM
DDDaniel DDDaniel is offline
Hey soundburst, i work with a stylus too, but my surface (wacom 21) allows me to program softkeys on the left and right side which I assigned to shift/cmd/ctrl etc... Dont know if you have that option?
I combine this with a eucon transport where I assigned some other often used key commands to the softkeys.
Together they allow me to work without a keyboard, except for typing names
Dan
Old 11-20-2013, 12:06 PM
Dan
That's a smart idea. . .I don't use those side buttons so will try them out!
Thanks to everyone else for responding.
Is is possible to change the shortcuts for the Pencil Tool, Grabber Tool, ETC? jgagne1 macOS 2 09-24-2013 07:46 AM
Get Grabber tool (Object) as part of smart tool? buckaroo Pro Tools TDM Systems (Mac) 8 07-13-2010 04:21 AM
PT8 Bug? - Selector/Grabber/Smart Tool Dallas Taylor Post - Surround - Video 2 12-27-2008 07:39 PM
Object Grabber and Smart Tool savetruman Pro Tools TDM Systems (Mac) 0 02-08-2007 12:19 PM
smart tool gets stuck in grabber mode jimlongo Pro Tools TDM Systems (Mac) 0 06-08-2006 07:01 PM
