Strange install problem MBOX 2 Mini + Pro Tools LE
Recently, my Pro Tools LE + Mbox 2 Mini system was running a little bit flakey, so I uninstalled it, along with all the plugins i had installed. Restarted, then as i tried to install again (plug in Mbox via USB port, tried several) my pc made 3 weird sequential chimes, you know the one you get when it recognizes a piece of hardware, but they were short and back to back. For some reason its not recognizing the interface and i have no green light either on the unit, so something is definitely going on. Never happened before.
Just so I have no redundant questions, I have uninstalled everything completely, drivers and all and restarted several times, still getting this problem every time i try to plug in my interface. My PC runs great, its pretty fresh (hard disk has been formatted awhile ago, everything is up to date) so I can't figure out what is causing this. Anyone have any ideas? Maybe manual uninstall something I am missing?? Thanks PC Specs: WinXP SP3 ASUS P5N-SLI mobo Intel Core 2 Duo E 7600 3 GHz CPU 3 GB (3x 1 GB) PC2-5300 memory 1x WD 250 GB SATA HDD (8 MB cache) 1x Nvidia GeForce 9800 GTX+ 512 MB Video Card |
Re: Strange install problem MBOX 2 Mini + Pro Tools LE
"Running a bit flaky" is somewhat ambiguous, but I will venture a guess from your equipment list that you were recording to the system drive? You need a separate
dedicated audio drive for this to become 'un-flaky." |
The hard drive observation is spot on.
Also running an Intel processor with a non-Intel chipset is known to be problematic with Pro Tools. What version of PT are you running? Have you allowed any Windows updates to creep in to the system?
Hi there,
Does the Mbox 2 Mini show up at all in the Device Manager? If so, you may want to try the troubleshooting steps in this article for performing a manual driver install: http://avid.custkb.com/avid/app/self...river+manually Best of luck, |
a very strange problem with mbox mini 3 | oplatner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-19-2012 07:36 AM |
003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice? | Timmus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-28-2010 07:41 PM |
003 and Mbox 2 Mini - Do I Need to Install Pro Tools LE Twice? | Timmus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-28-2010 03:42 PM |
MBox 2 mini/pro tools 8 LE install error | Menulo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-27-2009 01:47 AM |
Can't get Windows XP to install Mbox Mini for Pro Tools 8 installation | jacobmoon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-05-2009 08:22 PM |
