Problems using eleven rack with cab
hey I've had my eleven rack for almost a year now and been using it fine as a recording interface but the other day I tried to use it as a amp head as described in the user guide and I can get a decent signal
I've plugged amp output 2 into my orange cab, all cables are fine and followed the instruction and I can hear a very quiet tone but no matter how much I turn the volume up its still barely audible. any suggestions forum? I've also tried different output settings but its the same issue. |
Re: Problems using eleven rack with cab
output to amp --> direct to cab?
you need a power amp in between that to get the signal right.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
You need either a power amp, or a guitar amp with an effects loop. The 11r does not supply the power to drive a speaker cabinet.
Or an active cabinet :)
(like an Atomic Reactor, Tech 21 powerblahblah 60, etc.) |
Eleven rack Live problems. | Angelo Bruschini | Eleven Rack | 0 | 09-18-2013 08:49 AM |
PT10 and Eleven rack problems | Sessionace | Eleven Rack | 6 | 07-04-2012 07:22 PM |
Eleven Rack Problems | hero12300 | Eleven Rack | 8 | 06-26-2012 10:14 AM |
Eleven Rack Problems with USB e Drivers | DaniTo | Eleven Rack | 1 | 06-23-2012 06:05 PM |
Problems With Sound Using Eleven Rack | Dead-Eternity | Eleven Rack | 7 | 08-13-2011 07:56 PM |
