12.5 Elastic Sound Quality
Elastic Audio on 12.5 is broken - Totally glitchy audio - turn off elastic audio glitches go away. Even tried my Apollo.
The audio sounds like clock jitter - but its' not because disabling elastic audio removes the glitches. Tried realtime rendered/Poly/Mono/XForm - they all do it mono is better than poly but its' still unusable. Mac Pro 2013 12 Core 32GB RAM OSX 10.10.5 12.5 HD FWIW I have never had issues with Elastic Audio or Elastic Pitch ever.... |
Re: 12.5 Elastic Sound Quality
Have you Opened a Support Case for this ???
this sounds very bad ... Quote:
There's also some graphical bugs in elastic audio (x-form rendered) where the waveform isn't drawn in some cases, though the sound remains intact.
Can't say I have any glitches with rendered x-form though... |
AVID, you take money from us, and we ask you just a stable and usable version of pro tools (12.5 is a trash version). What are you doing with the world standard DAW???? WAKE UP. |
Don't get your hopes up - this one has been on the Avid "fix it" list for 5 years : http://protools.ideascale.com/a/dtd/...a-tab-comments
__________________________________________________ _______________________________________ Intel i7-2600K @ 3.40GHz + GigaByte Z68X-UD3H-B3 + Noctua NH U12P SE2 + 32GB + EVGA GTX 950 SC+ Windows 10 Professional x64 + 4K Monitor + RME 800 StudioOne + Cubase (+ Pro Tools for simpler old stuff) |
Don't get me started...I'll try to stay as on topic as possible for this one...
Ahem--Elastic Audio gives me random glitches/blips on playback in Pro Tools 12 constantly. Its very easy to replicate (just use it, lol). Thankfully, these glitches are not present when you commit the EA. Metalmixer, what version of Pro Tools are you upgrading from? The X-Form algorithms are best in 7.4, so if you are upgrading from that particular version, be prepared to be disappointed in X-Form's quality. |
I remember Izotope showing up around DUC explaining why 7.4 was better and later worst, it was his algorithm back then it seems.
Perhaps they no longer have anyone capable of finding the '1' in the code and changing it to a '0'? Or the other way around ... I'd have to track down the original thread to confirm high way it SHOULD be set. I'll try to find it later.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Ok so this is the thread ...
http://duc.avid.com/showthread.php?t...t=Xform&page=2 Post 47 in the thread is when it gets really interesting. It's by Alexey Lukin of Izotope. If you don't make the effort to read posts prior to #47, then you should read everything after, as it explains what we think has gone on very well. Also, importantly, post #55 includes this link ... http://protools.ideascale.com/a/dtd/81879-3779 in which the relevant details have been used to create an ideascale item on the subject to persuading Avid to fix x-form.
Good work! Now let's hope Avid, one of these days, will act on this. Unless PT is total spaghetti code with no documentation, it should be very easy to find and change the API call(s) to iZotope algorithms/DLLs even by a new programmer. It is a question of priorities...
Crappy elastic audio sound quality? | DJ Hellfire | AAX Plug-ins | 143 | 02-22-2022 11:02 AM |
better quality power cable = better quality sound? | dbvoyager | General Discussion | 22 | 04-15-2012 06:08 PM |
Elastic Audio sonic quality | BDWillis | Pro Tools TDM Systems (Mac) | 58 | 08-20-2009 03:12 PM |
What makes the quality of the sound...sound 100 times better... | musiclovin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 07-11-2009 04:55 PM |
ELASTIC AUDIO - A GOOD QUALITY RESULTS ? ON BASS TRACKS ? | djani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2007 06:16 PM |
