Digidesign 192 Input card problem
Hello,
I just purchased a second 192 used and there is an issue with the input card. Here is a video. I switch between inserts 5-6, 3-4, and 1-2. 5-6 are the worst, the crackling is very clear. I have tried everything from restarting my system to switching places with my functional 192. Both units have the exact same cards. https://m.youtube.com/watch?v=VX8LypBcrjQ Does anyone know what is wrong? Thanks |
Re: Digidesign 192 Input card problem
The video isn't much help(to me anyway). Here is how I would troubleshoot:
1-Assuming all was fine with the older 192, disconnect it and connect the newer 192 alone and test all the IO. 2-if that tested bad, return it for a refund 3-if it tested good, the reconnect the second 192 and triple-check all the connections. Not knowing your experience level on this, This info may be old-hat....but check these things: 1-loop sync(BNC cables must be in place, correct and solid) 2-if things are not working with 192 #2 connected the the Expansion port of 192 #1, try connecting #2 directly to your card(which you failed to mention at all)
Ah I did what you recommended, disconnected the old working one for the new one, that tested bad. Exact setup and card types too. This is disappointing because the seller told me everything was in working order when shipped.
This is going into an HD Accel card btw. |
Here are some similar threads:
http://duc.avid.com/showthread.php?t=259853 http://duc.avid.com/showthread.php?t=249887 Some are old but they have the same problem. Newer: http://duc.avid.com/showthread.php?t=398656 https://www.gearslutz.com/board/musi...cks-noise.html There are MANY threads wirh this exact issue.
Had the same issue on my input card and stripped everything out on the 192 and swapped the ribbon cable. All 192s have 4 ribbon cables one for each expansion bay so if you have an empty bay youll have a spare ribbon cable. Anyway it fixed it for me. Chris
Ok its definitely not a clock issue because I simply swapped units to test, and not a ribbon issue, I tried contact cleaner, as well as I put the input card into the expansion bay and it still does the same thing. This must mean the Input card is malfunctioning right? Any way to get it up and running?
Digidesign 192 A/D input card issues... | Justin1524 | Pro Tools HDX & HD Native Systems (Mac) | 6 | 12-29-2020 10:34 PM |
WANTED: Host card for Digidesign Expansion HD chassis (pcie ethernet card) | topdiggy2 | Buy & Sell | 0 | 02-04-2015 08:22 AM |
Digidesign 192 Analog Input Card and Analog output Card for Sale | MusicEngineer | Buy & Sell | 1 | 03-03-2014 09:03 AM |
Huge Digidesign PCI Express Core HD card BSOD problem | Gorazd Koncar | Pro Tools TDM Systems (Mac) | 3 | 03-10-2009 07:22 PM |
digital input problem on AM III card | admuser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-10-2001 07:10 AM |
