Old 11-25-2020, 06:23 AM
mariuste86 mariuste86 is offline
Default IK Modo Drum and Pro Tools?
Hello!
I recently purchased a license of Modo Drum SE from IK multimedia but I am having a hard time getting it to work on my Pro Tools. When launching PT I get the "not a valid 64 bit aax plugin" message and PT suggests moving it to the unused folder. I am on 12.7.1. Works fine in standalone.
My question is, does anyone of you get this plugin to work with PT? If so, what's you version of PT and Modo Drum?
Marius
Old 11-25-2020, 08:08 AM
Ben Jenssen's Avatar
Default Re: IK Modo Drum and Pro Tools?
Hei, Marius.
Welcome to the forum.
I can't really help you, it should be working.
But to get any assistance here you really should go to the User CP (left-most in the forum menus) and create a signature with the most basic info on your hardware, OS- and software versions etc.
And have a look here, if you haven't already:
Help Us Help You
I hope you'll get it sorted out.
Old 11-25-2020, 11:38 AM
Hei Ben, thank you for that and thanks for replying. I will do what you are suggesting:)
Old 11-25-2020, 11:59 AM
Added my signature now.
Macbook Pro Retina 15 inch late 2013, 2Ghz Intel Core i7, OS 10.9.5, Motu 8A audio interface, Yamaha NS10Mstudio, Behringer Truth B3030A studio monitors, Pro Tools 12.7.1.
Old 11-28-2020, 08:34 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Originally Posted by mariuste86 View Post
Hello!
Marius
Have you tried to uninstall and reinstall it?
Also have you tried to delete the Pro Tools preferences after uninstall and reinstall?
Old 11-28-2020, 10:41 PM
Top Jimmy's Avatar
Originally Posted by chrisdee View Post
I would also re-download the installer. Yes, a zipped installer should be fine when unzipped but I’ve had the same problem and downloading a new installer and re-installing again fixed the issue.
James Cadwallader
Old 11-29-2020, 08:31 AM
Hei Chris,
I have tried deleting the Pro Tools prefs once yes, but not reinstalling the plugin. I will try what you are suggesting, thanks.
Old 11-29-2020, 08:33 AM
Will do, thanks Jimmy
Old 12-18-2020, 10:06 AM
I will give an update. I tried both re-downloading the installer and re-installating, deleting prefs both before and after. No change so far. I even contacted support but I haven't got any reply which suggest they don't know either.
Ofc I am using an old OS now so I am using the last PT update supported with this (12.7.1). However, Modo works in standalone on my OS even though it is old (which is also confirmed on IK multimedia site).
However, since it doesn't seem to be a solution I think I will just have to accept that Modo Drum doesn't work in PT 12.7.1 on my system.
Therefore, since I am still eager to get this working, the only solution left seems be to update from my current version.
MODO DRUM Hot Deal - Save up to 50% off MODO DRUM RyanIK Partner Announcements 0 05-08-2020 02:28 PM
MODO DRUM 1.1.0 Now Available Peter - IK Multimedia Partner Announcements 0 12-06-2019 03:11 PM
MODO DRUM Now Shipping! Peter - IK Multimedia Partner Announcements 0 08-08-2019 08:19 AM
August is MODO Month! Save on MODO Bass Peter - IK Multimedia Partner Announcements 0 08-01-2019 08:45 AM
Announcing MODO DRUM Peter - IK Multimedia Partner Announcements 0 06-20-2019 02:38 PM
