Control surface
I have the Presonus Faderport controller and was wondering if anyone uses this with Pro Tools 12..If you do, how well does it work? If not, is there a controller you suggest? Sometimes I just get tired of using the mouse to adjust my gain on my tracks and having to use the mouse for other various things also
Control surface
I use faderport with 12.7 W10 and I don't know if there is something wrong with my faderport unit but the fader is sticky, almost like the motor is constantly engaged. When I move it, it seems to have resistance
Sent from my iPhone using Tapatalk |
Re: Control surface
Working fine here on 12.7. The new 8 fader version looks pretty stellar if you want more controls.
Re: Control surface
might be bad, or might need a better grounded circuit. I am guessing that the system is designed around capacitance touch? if so then yeah I would try a different electrical outlet.
Re: Control surface
Sent from my SAMSUNG-SM-N920A using Tapatalk |
Re: Control surface
I use the Faderport 8 with PT.
I used to have the Artist Mix but sold it to get the Faderport. Unfortunately the Artist Mix was incompatible with Studio One which I use for some things so I moved to the Presonus. t has a lot of nice features and integrates well with ProTools but I have noticed that it is a step down in quality. The faders feel imprecise and laggy. Also, you are stuck with the HUI protocol which is a fairly antiquated format. You are limited to 4 characters for channel names which, for me, is a big drag. Snare Take 1 becomes Sne1 etc. |
Re: Control surface
Thank you I will try that later. Sent from my iPhone using Tapatalk |
Re: Control surface
Not convinced grounding will matter as the faderport uses an ungrounded wall wart. Maybe try another USB cable and/or port? Have you set it up under the Peripherals menu as a HUI device?
Re: Control surface
Thanks Albee, yes it is setup as a hui device. I will try change the USB port and cable when I get home.
Re: Control surface
If the fader is capacitive touch activated try this - hand cream. Don't laugh - it works. One place where I used to work for antistatic protection everyone used wrist straps to a grounding block. Some days people would have problems with getting a good enough ground and we found out it was due to dry skin. A little hand or skin cream and problem solved. You don't need much.
Control surface : Mix + Virtual Inst control (PT12 HD) | redmount | Virtual Instruments | 4 | 03-30-2016 02:42 PM |
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
D-Control Es32 Control Surface No Sound from Headphone outputs | mark007 | Pro Tools TDM Systems (Mac) | 0 | 02-08-2012 07:03 PM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
