Old 03-05-2010, 06:01 AM
Eric Tannery Eric Tannery is offline
Default Eleven rack: mono track to record the processed guitar signal
How do I record a processed mono track with elven rack?
Old 03-05-2010, 03:11 PM
sw rec sw rec is offline
Default Re: Eleven rack: mono track to record the processed guitar signal
Send the output of the track to a bus.
Make a new audio track...set the input of that track to the same bus as the
existing track. Arm new track...record.
Old 03-06-2010, 11:35 AM
i'll give it a shot. the manual says you can't use low latency monitoring when routing to a buss though...
Old 03-06-2010, 04:46 PM
yellowjacket yellowjacket is offline
As long as your rig is in mono (no stereo fx), you can just set the input to your track to be "Eleven Rig L/R.L". The left output also acts as a mono output.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4
Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800
Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667
Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1
Eleven Rack Only Recording Dry Guitar Signal no FX Imran5000 Eleven Rack 18 07-20-2017 07:50 AM
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack spankyq Pro Tools 10 8 04-20-2015 08:19 AM
Why Can't I Record Over My Eleven Rack Track! BryceJay Pro Tools 10 1 03-16-2013 04:15 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Can I go Guitar>Pedals>DI XLR out to Eleven Rack? (using Mic input for guitar) electricfiddle Eleven Rack 5 12-12-2011 06:57 AM
