Plugin Active Parameter Color Indicator
The plugin window on the display has a blue color indicator that indicates that the parameter is active on the D Command. I am wondering how to change to a different color. I find that the blue is hard to see, especially with McDSP. I can't seem to figure out how to do this using the color palette. I must be missing something
Re: Plugin Active Parameter Color Indicator
You mean the contour of the window right ? that makes it stick out a bit more then the others ?
afaik you can't change that. The color palette is for track indications / types and region colors ... things like that. Not for anything in the plugin windows.
Chris Lambrechts Applications Specialist- Live Sound |
thanks Chris
MIDI / Plugin parameter question | Hawk570 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-09-2010 08:56 AM |
Can the active peripheral color be changed? | dmacintyre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-15-2009 05:50 AM |
003 Console displays no plugin parameter | apfel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-12-2007 03:10 AM |
copy plugin data ,paste on another parameter ? | andre tchmil | Tips & Tricks | 2 | 01-17-2007 10:36 PM |
how do u assign midi conrtoller to plugin parameter? | hokuspocus | Pro Tools TDM Systems (Mac) | 2 | 03-20-2002 09:22 AM |
