Old 10-01-2013, 10:03 PM
notedmusic notedmusic is offline
Default Emulated MIDI
Hi all.
When I run my PT11.0.2 I cannot seem to start up my midi keyboard in Pro Tools.
All of my outputs are emulated, regardless if I use windows 7's "run as administrator" or not.
Any ideas?
My keyboard works great outside of PT.
Using Graphite 49.
Also: Trashing Prefs didn't do anything.
Composer/Sound Designer
Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909
HD Omni/Thunderbolt Native
A bucketload of libraries
www.Reverbnation.com/jedediahjenk
www.soundcloud.com/jedediahjenk
notedmusic.wix.com/jedediahjenk
Old 10-01-2013, 10:04 PM
Default Re: Emulated MIDI
Sandra:
Computer
Model : OEM
Chassis : Desktop
Mainboard : ASUS M5A99FX PRO R2.0
Serial Number : 1304108********
BIOS : AMI (OEM) 1903 07/11/2013
Total Memory : 15.92GB DIMM DDR3
Processors
Processor : AMD Phenom(tm) II X4 965 Processor (4C 3.69GHz/3.4GHz 8% OC, 2.17GHz IMC, 4x 512kB L2, 6MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2.17GHz (4.34GHz), 2x 8GB DIMM DDR3 1.45GHz 128-bit
Memory Module(s)
Memory Module : Kingston KHX1600C10D38GX 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : ACI ASUS VG23A
(1920x1080, 24.2")
Video Adapter : AMD Radeon HD 6800 Series (14CU 1120SP SM5.0 920MHz, 1GB DDR5 4.2GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 6800 Series (1120SP 14C 920MHz, 1GB DDR5 4.2GHz 256-bit)
Compute Shader Processor : AMD Radeon HD 6800 Series (1120SP 14C 920MHz, 1GB DDR5 4.2GHz 256-bit)
Storage Devices
WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") : 2TB (F:)
WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (E:)
WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (G:)
Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm) : 3TB (C:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (I:) (J:)
HP Photosmart C4400 (USB2) : N/A (H:)
ASUS BW-12B1LT (SATA150, BD-RE, DVD+-RW, CD-RW) : N/A (D:)
Logical Storage Devices
Archives (F:) : 2TB (NTFS) @ WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5")
EWQL HS (E:) : 466GB (NTFS) @ WDC WD5000AAKX-00ERMA0 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache)
EASTWEST (G:) : 932GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache)
Hard Disk (C:) : 3TB (NTFS) @ Seagate ST3000DM001-1CH166 (3TB, SATA600, 3.5", 7200rpm)
Hard Disk (J:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Hard Disk (I:) : 100MB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Removable Drive (H:) : N/A @ HP Photosmart C4400 (USB2)
Optical Drive (D:) : N/A @ ASUS BW-12B1LT (SATA150, BD-RE, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller
LPC Legacy Controller 1 : T2 87-21
Audio Device : ASUS IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : MSI Radeon 68xx HDMI Audio (NI Barts)
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : ASUS SB700/800 SATA Controller [AHCI mode]
Disk Controller : ASUS Asmedia 106x SATA Controller
USB Controller 1 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 2 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 3 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 4 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 5 : ATI (AMD) SB700/800 USB OHCI2 Controller
USB Controller 6 : ATI (AMD) SB700/800 USB OHCI0 Controller
USB Controller 7 : ATI (AMD) SB700/800 USB EHCI Controller
USB Controller 8 : ASUS ASMedia XHCI Controller
SMBus/i2c Controller 1 : ATI SB800 SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Photosmart C4400 series (1200x1200, USB, Colour)
Printer : HP Universal Printing PCL 6 (600x600, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard HP Photosmart C4400 (Scanner, 2400x2400, USB)
Peripherals
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : 802.11n USB Wireless LAN Card (802.11n (HT), 215Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 10-01-2013, 10:53 PM
My MIDI I/O doesn't work at all (emulated or not- no signal in or out) in PT 10 or 11, but it works great in all of my other software.
Let me be clear- it is detected. It is enabled as an input. It is not providing in/out throughput in PT only. It works just fine in my other apps (set on OMNI).
Midi thru does nothing. Midi tracks are receiving no data from the device.
Old 10-02-2013, 01:14 AM
Shan's Avatar
Shan Shan is offline
Does the Graphite 49 show up in the MIDI I/O section of the track?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-03-2013, 03:30 PM
Shane
Yes, it does.
Thanks.
Old 10-03-2013, 03:45 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Have you tried it on an instrument track, with the track record-enabled?
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 10-03-2013, 04:21 PM
Shan's Avatar
Along with the above, do you have a VI inserted on the track?
Shane
Old 10-03-2013, 07:55 PM
BigJohnD BigJohnD is offline
Don't know if this will help, but I had a similar problem with an M-Audio KeyRig49 MIDI controller keyboard after upgrading to PT 11. The solution (as pointed out by Avid support) was to update the keyboard driver to the latest version. Hope this helps.
Old 10-03-2013, 09:29 PM
Shane
Yes. and Yes. My VI track doesn't receive any midi data from the keyboard with or without record enabled.
I also set up a MIDI track direct input and it receives no data from the keyboard.
Sorry, my keyboard doesn't have any drivers. It is plug n' play. I did update the firmware, but it didn't fix the problem.
Thanks Guys.
I did a complete reinstall of PT11 just in case- to no avail.
Old 10-04-2013, 01:33 AM
8dB.co.uk 8dB.co.uk is offline
Thanks Guys.
One thing that always trips up midi on clean installs is to make sure you're running PT as an administrator. Right click your PT icon and select ""Run as Administrator"
Sent from my C6603 using Tapatalk 2
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
Output Midi Emulated Problem Jim Don Windows 1 10-13-2012 09:21 PM
MIDI out's EMULATED? reshp1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2010 08:47 AM
PTLE "Emulated" MIDI Ports? timtimtimtim 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-10-2007 03:49 PM
Emulated MIDI inputs? HotRats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-04-2005 01:23 AM
