All these plugs won\'t open on last 3 accel chips
I have HD3accel and i have filled all the accel chips except the last 3 chips on both accel cards (6 chips free) And i can't open these plugs... Revibe TL Space Eventide reverb Eventide factory Eventide band delays Eventide octovox Filter factory Echoboy Omnipressor Pitch doctor mach five Indigo time blender pitch blender BNR all get 7204 error What gives Digi? that's a lot of $ wasted Chris
Re: All these plugs won\'t open on last 3 accel chi
Seriously, we have 3 different chips types and not all plug-ins can run on all of them. Some 3rd party developers aggressively pursue supporting all chip types, some do not, some require extra ram, some do not. -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Re: All these plugs won\'t open on last 3 accel chips
You can try doing a force shuffle, are you using any non-ram plug-ins like EQ, Dynamic on the 4 Accel chips ? Move those to the last chips
Paul |
How do you force shuffle? how do you move plugs to chips? Chris
Dutchmuzik Wrote:
Thanks-
ROULETTE RECORDS™ (415)334-8742 office (267)219-4490 fax www.rouletterecords.com [email protected] Any fool can complicate things; It takes a genius to simplify them __________________ |
[quote
The last 3 chips on an Accel card are unique in their RAM memory allocations. The plug-ins you listed, require additional coding to support these chips, or they need the extra RAM which exists on the other Accel chips. Many multishell plug-ins favor/benefit from these last 3 chips, BTW. Its sort of like a tossed salad - depending on your ingredients (plug-ins) you can serve a Caesar with croutons, or a lite greens w/balsamic and almonds. Seriously, we have 3 different chips types and not all plug-ins can run on all of them. Some 3rd party developers aggressively pursue supporting all chip types, some do not, some require extra ram, some do not. -tv [/QUOTE] Hi, Yes i can see that there are 3 chip types... chips 1-2 then chips 3-6 then chips 7-9. I didn't recall ever having a problem before 7 and tiger! but now i have sessions that are half finished and i can't open anymore of the plugins i want to finish the session!! It's strange that certain plugs will open on a HD core card but won't open on chips 6-9 on accel!!! I have one session where it will try and re shuffle even when i try to assign an output or instantiate any plugin! when i have 3-4 accel chips free. Its the shuffleing that doesn't seem to be working right? i guess it would move stuff off of the chips 3-6 on accel to make way for plugs that have to go on them? but it shuffles and comes back error not enough DSP. Is it that i have just chosen so many plugs that require accel chip 3-6? so effectively i can only have 8 of those type plugs in a session!!! But this doesn't make sence when i try to open a Band delays which can use all chips except the last 3 accel, it still tries to shuffle but won't make a chip free for it. it should throw all the plugs that don't require accel 1-6 to other chips to make way etc. There does seem to be a lot of users experiencing this problem all of a sudden.
I too am having the same problems...
Wish there was a fix or something... I hate not being able to load plugs when I can see there are open chips on the card -Kurt
Kurt Bullock PT 7.4 HD2Accel Digi ProControl G5 Dual 2.7 3.5gig RAM OS10.4.8 www.zeropointrecording.com |
Open the system usage window. Deactivate the plugs you want to move. cmd /cntrl/click on plug when you've freed up a chip in your usage window click on that chip. This will temporarily <allocate> that chip. Now activate the plugs and see if they force load on the other chips. Also, TLspace loads on different chips depending on what 'size' you choose.
"What's the best mic under $100." |
Yes i can see that there are 3 chip types... chips 1-2 then chips 3-6 then chips 7-9. I didn't recall ever having a problem before 7 and tiger! but now i have sessions that are half finished and i can't open anymore of the plugins i want to finish the session!! It's strange that certain plugs will open on a HD core card but won't open on chips 6-9 on accel!!! [/QUOTE] The chips on an HD Core are different then the 6-9 on Accel, so again, if plug-ins do not support Accel 6-9 chips, they simply won't go there. I can't think of a reason that would make 6.9 and 7.0 behave differently in these types of situations. Can anyone prove this with a the same session? I'm all ears.... -tv
possible to bypass DSP chips on HD accel cards? | sound_music | Pro Tools TDM Systems (Mac) | 5 | 11-18-2012 06:27 PM |
Some confusion with Soundtoys decapitator and accel chips? | crizdee | Pro Tools TDM Systems (Mac) | 3 | 01-08-2011 03:42 PM |
Core Accel Chips usage error 7204 | innesireinar | Pro Tools TDM Systems (Mac) | 2 | 05-02-2007 02:06 PM |
Missing chips on Accel card? | Lee Blaske | Pro Tools TDM Systems (Mac) | 6 | 09-15-2003 01:34 PM |
Which plugs use which chips on TDM systems...? | knewbee | Pro Tools TDM Systems (Mac) | 0 | 02-22-2003 09:33 AM |
