  #331
Old 10-13-2011, 07:41 PM
DigitalMetal DigitalMetal is offline
Default Re: Best Systems and Components for Win HD/TDM
Im a long time PC HD TDM (HD3) user and rest assured PC HD is a safe place to be with PCI-X Cards.
I actually run a dual system with swappable drives between Win7 x64 and OSX 10.6 Hackintosh so i have both worlds to choose from so if ou really dont like windows you have that option too but be prepared to do a LOT of research before buying components if thats your preferred route.
Anyway im currently running an older Asus Motherboard (P5WDG2 WS Professional) but researching an upgrade.
What i will say is that you dont need PCI-X slots normal PCI are fine (the HD cards dont used full PCI-X bandwidth).
Anyway PT9 runs like a dream on Win7 and just a well as it does on OSX so once you are inside PT9 the only difference for you would be if you were using any Mac only plugins like Metric Halo Channel Strip etc etc.
PT10HD5 PCIX in 64Bit Magma Chassis,
2x192io's + 2x96io's & Legacy io's
Pro Control & Fader Pack
UAD2 Quad, Octo & All Plugins
Black Lion Audio Modified MOTU 24io and 2408MK3 x2
TC Powercore PCI MK2 x2 & Firewire
Softube, Sonnox, Eventide, SSL, McDSP, Waves
  #332
Old 10-17-2011, 04:29 PM
Frans29 Frans29 is offline
Are you really absolutely positive the cards will work in normal PCI slots? Isn't there any performance loss using them that way? I need all my cards to work at their best.
I've found a board with 3 PCI-X slots and will work with westmere and nehalem processors. Since these are used in Mac Pro's I figured this was a good starting point?
http://www.supermicro.com/products/m...8DA6.cfm?SAS=N
  #333
Old 10-17-2011, 06:32 PM
temetrepo temetrepo is offline
This one has been confirmed working by a few other members
http://www.newegg.com/Product/Produc...&Tpk=NAF92-Q67
See here
http://duc.avid.com/showthread.php?t=308489
Originally Posted by JustinA
"Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE?
  #334
Old 10-19-2011, 02:04 PM
RonTalley RonTalley is offline
See here
This is the one I ordered. Everything seems to work on it and it works well with OSX.
  #335
Old 11-05-2011, 07:48 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by matt crooks View Post
........i feel like i'm going to get several more years of use out of my five year old pci cards!
nice............
Daniel
  #336
Old 11-05-2011, 07:55 PM
im 100% sure, the cards are PCIX size but only PCI bandwidth,
  #337
Old 11-21-2011, 03:50 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Can anyone out there verify this MSI mobo is working in a PCI HD3 set up....
http://www.msi.com/product/mb/P67A-C...l#/?div=Detail
I know the 1155 mobo with the H67 chipset is a no go, but this one has the P67 chipset and I have been eyeing this one for a while now and I'm ready to pull the trigger if it'll work.
Thanks in advance.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #338
Old 12-01-2011, 08:58 PM
abc1mce2's Avatar
Thanks in advance.
After researching it and seeing that it too uses a PCI to PCIe bridge, I decided to go with the Jetway (i7-2700K) to replace my Gigabyte H55-USB3 (i7-875K) in the near future. I just got the mobo from newegg.com and once I feel like building a new system I'll start that project. I really can't wait to see what the preformance boost will be like....and I plan on going up from my HD3 to an HD4 set up since I don't see myself jumping into HDX anytime to soon.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
  #339
Old 12-03-2011, 10:46 AM
sonorelli sonorelli is offline
Are you talking about the Jetway NAF92-Q67? http://www.jetway.com.tw/jw/ipcboard...name=NAF92-Q67
That's the only board I've ever seen with 4 adjacent PCI slots. Sweet! I believe its possible to Hackintosh this board as well: http://www.tonymacx86.com/viewtopic....2&hilit=jetway
It looks like a lot of trouble, but if you want HD4, go for it.
Sonorelli
HD3 Accel PCI-x, Pro Tools 10.3.9 HD, OSX 10.8.5
Hackintosh - Gigabyte GA-H55-USB3, i7-870 2.93 GHz, 16GB RAM
  #340
Old 12-05-2011, 04:28 AM
abc1mce2's Avatar
That's the board I'm talking about...Haven't decided if I'm staying Windows7 or going for a hackintosh build yet. I might just try both on separate hard drives of course.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Are these pc components ok? chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-13-2010 11:20 AM
need help with HD components FMR_Crisis Pro Tools TDM Systems (Mac) 9 04-17-2010 05:07 PM
What components lie in the most POWERFUL native PTLE Systems? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-28-2008 07:18 AM
Will these PC components do the job hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-06-2007 08:22 PM
components rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-19-2001 09:32 AM
