Old 11-21-2002, 08:18 PM
MV MV is offline
Default Slowing down the tempo
Is it possible/OK to slow down the tempo of a whole song in PT(16 tracks)?Something like 5%,going from aprox 96bpm to 90bpm.If possible will there be some loss of sonic quality?
Does Pitch'n time do it?
Thanks
Old 11-21-2002, 08:35 PM
Cliff Adams Cliff Adams is offline
Default Re: Slowing down the tempo
I have done it with PnT2 on about 8 tracks with no noticeble problems. It should work on 16 tracks.
MasterPeace Sound
Old 11-21-2002, 09:25 PM
MV MV is offline
Thanks for the answer.Would you please explain the process to me?Sorry,I'm not an expert. [img]images/icons/blush.gif[/img]
Thanks
Old 11-23-2002, 12:59 AM
Hit$quad Hit$quad is offline
Speed from Wave Mechanics is a way to go for lots of time compression. I have been using Pitch and TIme 2 and Speed together. I noticed that PT2 tend to screw up timing if the track has lots of empty space. Speed does it more accurate. Maybe it was just me.
Althought, I love PT2 pitching with a graph.
Don't confuse kindness for weakness
Old 11-24-2002, 12:52 AM
MV MV is offline
Let's say I have a track with lots of regions.Would it be a good idea to consolidate the regions before applying Pitch and Time?Would this help the process in terms of trying to avoid messing up with the tempo?
Old 11-27-2002, 10:19 PM
I have had better luck waiting till i finished mixing the song, sub-mix to a stero file, then change the tempo on that file. Sometimes you get away with it, other times you can hear garbage. You will just have to try it. But I have never had trouble getting good results if i do mix to stereo first.
Old 11-29-2002, 01:19 PM
Dr. J Dr. J is offline
We've recently done some re-mixing of Dance tracks for actual dancers competition pieces. We just used the Digi-rack time expansion/compression tool, and it works flawlessly. I did not hear any sonic loss. I do not think you can match beats per minute though. We just saw the length of track at say 3:40 and moved the slider to 3:30 to cut off ten seconds. It was great. It's definately a fast and easy tool to try.
jay@jayriggs.com
www.jayriggs.com
www.fifty-fiftymusic.com
Turn Me Up!™ – Sign Up Now to Bring Dynamics Back to Music (www.TurnMeUp.org)
Slowing Down The Tempo of A Song Using Elastic Audio greenskyroly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-15-2010 03:55 PM
Best method for slowing down tempo? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2009 08:39 PM
Slowing Down Tempo w/ Audio Tracks Danos1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-17-2009 04:53 PM
slowing tempo jetidd Tips & Tricks 0 07-18-2006 05:09 PM
slowing down tempo thesego211 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-04-2005 12:07 PM
