Old 10-20-2003, 07:42 AM
Lord Humungous Lord Humungous is offline
Default Converting stereo to mono in PT
Hi all,
I was wondering if anyone is aware of a simple way to do channel converts in Pro Tools - for instance, if I import a stereo drum loop into PT and I want to sum the channels to mono. I'm not talking about using just the left or right channel of a split-stereo track. I want them attenuated and summed. I believe SoundForge does this quickly and painlessly (but I don't own it). Anyhow, if someone knows if Pro Tools can accomplish this I'd appreciate a heads up.
Thanks,
LH
Old 10-20-2003, 10:48 AM
Crabby Crabby is offline
Default Re: Converting stereo to mono in PT
Click the output button of your stereo track, then select "bus 1 (mono)" as your output. Create a mono audio track and make bus 1 its input. Record the stereo track to the mono track and your stereo track will be summed to the mono track.
Old 10-20-2003, 02:07 PM
metaltim metaltim is offline
if you go look under 'file' there is an option that says 'split selected tracks into mono'
is that what you are looking for??
tim
Old 10-20-2003, 09:03 PM
where02190 where02190 is offline
Split selected tracks to mono will give you separate left and right tracks as mono tracks. I think you are trying to make your stereo drums mono, perhaps to gain a track.
Pan them center will of coure make them mono, then bussing as described above and recording will give you a single mono track of your stereo drums.
Old 10-20-2003, 10:11 PM
King Kong King Kong is offline
how about just select your stereo trakcs, then go to 'Audio File' and select 'export selected file as' and set the export part to mono.?
King Kong
Converting Stereo to Mono Tritonemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-05-2011 03:24 PM
Converting Stereo to Mono audio trax DonaldM Tips & Tricks 12 11-10-2009 06:00 AM
converting stereo tracks to mono bigboi78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-23-2005 12:42 PM
converting a mono track to stereo cdp2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-07-2004 06:38 AM
Need help converting a stereo track to mono Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2004 09:30 AM
