Old 01-17-2009, 01:52 PM
Danos1 Danos1 is offline
Default Slowing Down Tempo w/ Audio Tracks
This is probably the simplest question but still I am not sure what to do & have tried a few things.
Using PT 7.1.2 LE on PC: Just want to know how I can slow down the song I am working on - so the audio plays slower (so I can check a few things/spots which are hard to discern when playing at the normal 140 tempo). And I am ONLY listening to audio tracks right now (NOT any midi). I tried a few things using the transport but no luck.
Thank you..
Old 01-17-2009, 03:02 PM
TOM@METRO's Avatar
Default Re: Slowing Down Tempo w/ Audio Tracks
Ctrl+Shift+spacebar 1/2 speed record
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-17-2009, 03:45 PM
I hit Ctrl+Shift+spacebar - but it just says "No tracks are record enabled".
Old 01-17-2009, 04:02 PM
TOM@METRO's Avatar
Sorry... Shift+spacebar for 1/2 speed playback
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 01-17-2009, 04:22 PM
The Weed's Avatar
The Weed The Weed is offline
· Half-speed Playback: Shift + Spacebar.
· Very Slow to Very Fast Playback: Start Key + 1 through 9 on the Numeric keypad will start Playback at very slow to very fast speed with 5 being normal speed on up to two tracks while in Shuttle Lock Mode. Pressing “+” or “-" will change direction, pressing a different number will change speeds. Press Numeric Keypad 0 to stop Playback, press a Playback Speed Number to resume Shuttle Lock Speed. Press Escape or Spacebar to exit Shuttle Lock Mode. Set the Custom Shuttle Lock Speed for Start Key + Numeric Keypad 9 under Preferences>Operation. This can be set between 50% and 800%. The default is 800% and the setting is saved as a Global Preference, not just with the session.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-17-2009, 04:53 PM
Thank you. I know about straight 1/2 speed.
And I tried using Start + #'s - definitely a useful tool if you want to isolate 1 or 2 tracks only. Thanks!
But I am still curious if there is a way (& HOW) to: simply slow down (or speed up, but in this case slow down - manually if possible) the playback of PT audio tracks - just for listening/evaluating purposes. And in doing so affecting many (or all) tracks, not just 1 or 2 - the same way it does iwhen simply triggering the 1/2 speed - playing all active tracks - (but giving you more control to vary playback speeds than simply normal or 1/2).
Again, many thanks..
Speeding Up/Slowing Down Audio Tracks? TigerTwin macOS 2 08-19-2011 06:38 AM
Slowing Down The Tempo of A Song Using Elastic Audio greenskyroly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-15-2010 03:55 PM
slowing tempo jetidd Tips & Tricks 0 07-18-2006 05:09 PM
slowing down tempo thesego211 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-04-2005 12:07 PM
Slowing down the tempo MV Tips & Tricks 6 11-29-2002 01:19 PM
