Old 01-04-2005, 09:16 AM
thesego211 thesego211 is offline
Default slowing down tempo
my friend who is a drummer recorded some drumbeats using his protool 002 rig. i imported them into my own protools 6.4 mbox/macG5 setup. is there a way to slow down the tempo of a track? i tried highlighting the track that has the drums on it and then messing with the 'tempo' function. even when i changed the tempo to something else in the tempo window the track itself still played at the same speed. since the tempo function appears in the midi dropdown menu i wasn't sure if it just applies to midi tracks. the short of it is that i haven't been able to slow the drumbeat track down at all. but maybe i'm just out of luck. thanx for all the help!
-chuck
Old 01-04-2005, 09:44 AM
nueme nueme is offline
Default Re: slowing down tempo
http://duc.digidesign.com/showflat.p...fpart=1#750476
I asked the same question about a week ago and this is the link to the responses (I think). If you got $700 dollars to spend your troubles may be over. My question was in reference to audio data. I think you may be looking at the MIDI tempo function. Are you working with a MIDI track or an audio (wave) track? FWIW I can't get the audio tempo 'slow down/speed up' audiostuite function to work either. Good luck.
nue
Old 01-04-2005, 09:58 AM
thanx so much for your reply. the track in question is NOT a midi track, but an audio track. i'll try some of those things mentioned in the link you included with your reply. thanx again!
-chuck
Old 01-04-2005, 12:07 PM
jlcnyc jlcnyc is offline
to change the tempo of an audio track, you need to use "time compression/expansion" in audiosuite...or the TCE tool in 6.7
Unfortunately if you need more than a couple of bpm's of difference(faster or slower), you will notice that the audio will degrade significantly. It's not a miracle worker (more like band aid for small problems)
www.jeffreyleecampbell.com
Mac Pro 2.8 GHz Quad
16GB RAM
Apogee Rosetta 200/ UA LA-610
Genelec 8030A/7050b
McDSP, Waves, Sony, URS, Spectrasonics, BFD, Altiverb
Slowing Down The Tempo of A Song Using Elastic Audio greenskyroly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-15-2010 03:55 PM
Best method for slowing down tempo? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2009 08:39 PM
Slowing Down Tempo w/ Audio Tracks Danos1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-17-2009 04:53 PM
slowing tempo jetidd Tips & Tricks 0 07-18-2006 05:09 PM
Slowing down the tempo MV Tips & Tricks 6 11-29-2002 01:19 PM
