Xpand! v1.0 to v1.0.1 Updates
for some reason, the updater refuses to update my installed copy of Xpand!. I keep getting the error "installation failed, please try again"
I've tried reinstalling the original Xpand from the CD to no avail.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
Re: Xpand! v1.0 to v1.0.1 Updates
Hello. Same here.
(From TDM Post) R-Permissions, reinstalled from disk and the updater still will not update. On another note: I also noticed the Plug-in setting folder for Xpand is (red X) locked for preset settings, I replaced this with my own Xpand! folder which allow for my settings to be save. For the updater as I mentioned I backed up (Moved) my settings and did a reinstall from the original disk. PT's HD7.1cs5, OS 10.4.5 Xpand pi Version 1.00.701 Xpand .dat located in the Digidesign applications support folder (As installed) P.S. Original Xpand works otherwise. |
I can't get the upgrade to work either. I don't get an error message but the version is still 1.0.0.701 after running the upgrade installer.
/T - G5 Dual 2 ghz, OSX 10.4.5, 1 gb RAM, PT LE 7.0, Digi 002R |
Can you tell me how the permissions are set on the Xpand.dat file?
OK. The Xpand!.dat-file has the following permissions:
Ownership and permissions: You can: Read and Write Details Owner: My own user (which is also admin on the computer) Access: Read and write Group: My own user (which is also admin on the computer) Access: Read only Others: Read only /T |
.dat file permissions are: owner: read & write group: read only others read only
Xpand! v1.0 to v1.0.1 Updates | OC Cool | Virtual Instruments | 4 | 08-09-2006 12:30 PM |
Xpand! v1.0 to v1.0.1 Updates | Wolfram K | Virtual Instruments | 2 | 04-10-2006 02:54 AM |
Xpand! v1.0 to v1.0.1 Updates | David MacNeill | Virtual Instruments | 6 | 04-09-2006 11:36 AM |
Xpand! v1.0 to v1.0.1 Updates | formento | Virtual Instruments | 1 | 03-29-2006 07:43 AM |
Xpand! v1.0.1 & 1.0.3 Updates | Avid | Virtual Instruments | 0 | 03-06-2006 05:12 PM |
