Old 03-23-2024, 08:38 AM
rdpar's Avatar
rdpar rdpar is offline
Default Disk Cache problems
When I open a session, no mater what the disk cache is set on, frequently the audio clicks and pops and the tempo sometimes slows down. To resolve the issue, I have to change the cache size. It does'nt matter if I start high and change to low or start low and change to high. Now,also quite frequently, this happens in the middle of a session when i and loading or modifying plugin settings. It's maddening. any idea what's happening.I have all brand new drives
which did not help at all.
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE)
Old 03-25-2024, 08:32 AM
Default Re: Disk Cache problems
More details might help;
1-You say you have new drives, was it working fine before the new drives?
2-How exactly are the new drives formatted and partitioned?
3-What are these new drives(SSD, NVMe, spinners...)?
4-How much disk space do you normally assign(and what happens if you select "Normal" instead of a specific amount)?
5-(as I am not familiar), how does the Apollo connect?
Shooting from the hip, I kind of doubt its actually Disk Cache causing the problem, but changing it is doing something "under the hood" to give a temporary fix. with 32GB of RAM, I usually set cache to 5-6GB and never had an issue(which is why I think it may not be the direct problem).
Old 03-25-2024, 11:48 AM
Are you talking about disk cache or hardware buffer size? You are describing a not too unusual behavior of the *hardware buffer size*.
Is ignore errors enabled? If it is the disable it and troubleshoot the underlying CPU errors. Do all the standard stuff...
If disk cache, how large a disk cache are you setting and does that fully cache the session to start with? ... Look at the meter turning green. Are later issues related to the cache filling? Again, watch the meter.
Where is your clear system info? Including disk drive info if you are suspecting them. "SSD" tells little useful info. Just post a Sisoft Sandra report.
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? sunburst79 General Discussion 6 09-15-2011 11:28 AM
Disk Cache is too small? Problems! AbjectEvolution Pro Tools M-Powered (Win) 10 02-21-2008 09:06 PM
512 Disk Cache ? Felix Tips & Tricks 2 03-21-2002 07:30 AM
