Old 12-30-2023, 06:26 PM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default Beating Pro Tools Delay Compensation tip...
I'm on latest Ultimate, HDX card, M1 Mac Studio.
Firstly run in Hybrid mode - it's better than straight HDX - at least this system works better in hybrid mode.
On an audio track load up your most hungry Dly Comp plugins - so it's crazy high (see photo - track to the far right)
In my examples I've got it up to 50304 samples.
I run an analog 2 bus so that will never be correctly compensated but I don't find that an issue.
I can now run all the hungry plugins like Sonible and Sound Radix
Without having to "Freeze" the track.
Hope this helps someone.
File Type: jpg Screenshot 2023-12-31 at 12.10.45 pm.jpg (96.4 KB, 0 views)
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
Pro Tools Ultimate 2023.12
HDX card
AVID TB3 1 slot PCie Chassis
Old 12-30-2023, 06:53 PM
Default Re: Beating Pro Tools Delay Compensation tip...
I am not following you. What specific delay compensation problem does this help avoid?
Ditto for having to freeze tracks, what delay comp problems does freezing a track help solve? (sure it can help refine DSP and CPU resources, but that is not not ally related to ADC problems)
Old 12-30-2023, 06:58 PM
In sessions when using high latency plugins like Sound Radix Pi and the Sonible Ai plugins
It's quite common for your delay compensation on some tracks to be orange or red
Meaning they aren't being correctly compensated
Which equals the audio playing back out of time
Traditionally the work around is to freeze the track or plugins up to a slot of your choice
to bring them back into time
but then you can't edit the audio as it's 'frozen'
This techniques I've come up with resolves this problem.
File Type: png Screenshot 2023-12-31 at 12.49.32 pm.png (36.1 KB, 0 views)
File Type: png Screenshot 2023-12-31 at 12.50.51 pm.png (36.9 KB, 0 views)
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 12-30-2023, 08:02 PM
BScout BScout is offline
Orange means it is the max being compensated of all the tracks. It is still being compensated. Red means it’s exceeded the ability to be compensated.
Your solution doesn’t change what’s compensated or not. You’ve just made everything NOT compensated. Always.
Which is a way to work but not one I’d go with.
Old 12-30-2023, 08:08 PM
All my session audio and aux tracks are yellow / green
2 bus is red
Heavy comp track is red.
All audio plays back correctly
Means happy Angus. 😇
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 12-31-2023, 11:49 AM
LDS LDS is offline
2 bus is red
Are you saying that your tracks aren’t green or orange if you remove all of the processing off your faux master bus? I would expect them to all be green/orange as they are lower than the maximum 16383 samples of ADC that Pro Tools has.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 01-02-2024, 12:36 AM
Ok. So you guys are correct. My loaded plug-in does not solve red delay compensation issues. Help please.
https://youtu.be/A4JGRcO1tto?si=hOkTpU37Z7pgtVfG
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 01-02-2024, 01:56 AM
Help?
You put large latency plugins on the master fader and let them delay everything, but that does not count against the ADC limit (well except for the the broken behavior of master fader ADC actually counting to the limit) a few releases back.
You avoid using large latency plugins/plugin settings outside of the master fader.
You manually slide stuff around to solve latency problems.
No I am not defending the embarrassing low ADC limit of Pro Tools here. Avid has needed to improve this for ages, and get Pro Tools out of obstructing users workflows.
Old 01-02-2024, 02:12 AM
LDS LDS is offline
I would try and rule out the presence of bugs first. The HDX Hybrid engine is riddled with delay compensation related issues. Perhaps try changing the session to a different playback engine, even if it is just your onboard computer sound card, and see if the delay issues vanish. There are plenty of threads about the problems and probably a decent number of know bugs listed in recent release notes.
If you can't narrow it down to something HDX/Hybrid Engine related, it probably boils down to plugin selection. Personally, I print all my auto-align as part of the edit/session prep process. Once the tracks are aligned, I have never found a need to tinker with them further to justify keeping auto align as a realtime process. There is a lovely serenity in committing to a sound.
Beyond that... it is probably too many "smart" and lookahead plugins. 16383 samples equals 350ms of delay. That is a lot. The best sounding 'smart' process I have ever heard in my studio is my Trinnov, and it does all its processing in just 24ms.
You have a great set of ears on you, Angus. If you dig into the problem and find it is the result of plugin selection, I highly recommend returning a bunch of the processing back to basics. For highly complex resonances, the smart stuff has a place. Beyond that, it seems to quickly become a crutch of laziness for many audio engineers rather than something the genuinely improves the final product.
Old 01-02-2024, 02:27 AM
Originally Posted by Darryl Ramm View Post
Help?
Thanks guys
Good points here
I must admit I'm enjoying the auto type plugins as a way of sorting out nasty stuff fast and easily
So then I can focus on creative EQ choices
In some sessions I get away with it (no red DC)
In others I don't
Need to get more serious about getting under the hood and really understand how PT works
I have a love / hate relationship with the software (am I allowed to say that here)
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Pro Tools 10 delay compensation problem TheLastHobson macOS 11 08-25-2013 12:50 PM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay Compensation In Pro Tools LE RussUK General Discussion 22 12-10-2009 02:31 AM
Pro Tools 8 LE: Delay Compensation ETA? devkerr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 01-21-2009 09:38 AM
My problem with Pro Tools HD 7.2 delay compensation jacko Pro Tools TDM Systems (Mac) 5 03-19-2007 12:10 PM
