Old 12-04-2023, 12:23 PM
c-post c-post is offline
Default toggle all tracks doesn't work right
Hey, when I hold down option and press the hyphen key, toggle all tracks isn't working. I should be able to toggle all tracks between regions and volume. For some reason, when I start up a session, OPTION/HYPHEN only toggles the volume lines on, but OPTION/HYPHEN won't toggle the volume lines off. Am I getting rusty? What am I doing wrong?
thanks
John
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 12-04-2023, 12:40 PM
BScout BScout is offline
Default Re: toggle all tracks doesn't work right
option+hyphen is working here to toggle back and forth (but I'm 2023.9)
You are in the legacy section, so which version of Pro Tools?
Old 12-04-2023, 08:29 PM
6.4.1. Yeah, this function had worked properly for years. Hmmm, I wonder what happened. Option DASH is one of those essential commands for Protools to run smoothly.
John
Old 12-04-2023, 09:09 PM
The obvious answer is to reinstall 6.4.1
J
Old 12-04-2023, 09:45 PM
J
You might just need to trash preferences instead of doing a reinstall (a reinstall won't fix it if it is preferences because that won't get cleared out/over written)
Old 12-13-2023, 01:04 PM
Oh WOW. I forgot all about that. DEFINITELY worth a try! Even if it doesn't work, THANKS A BUNCH. Guess I'm a bit rusty.
JCG
Old 12-13-2023, 03:00 PM
Yeah, I tried trashing Protools 6.4.1 preferences and that didn't work. OPTION/hyphen turns ON volume for all tracks as it's supposed to, but it won't turn volume OFF, failing to return to region editing.
thx
John
Old 12-28-2023, 11:39 AM
Even after reinstalling PT 6.4.1 again and trashing prefs again, option-dash STILL does not turn off volumes for all tracks. My next option is to swap out my main drive for a backup I have and try that.
JCG
Fit All Tracks Vertically shortcut - doesn't work Gorantovic Pro Tools 4 09-20-2021 11:30 AM
ZOOM TOGGLE doesn't work when PT is playing Benny Mouthon Pro Tools 3 08-05-2021 03:31 AM
The shortcut to toggle to next or previous playlist doesn't work reznovmax Pro Tools 12 0 06-07-2021 08:02 AM
Tab to transient doesn't work on elastic tracks BGee Pro Tools TDM Systems (Mac) 2 11-09-2007 12:07 PM
toggle view keyboard shortcut doesn't work Saar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2003 08:54 AM
