Re: Adding accel card to Pro Tools 8 HD Mac
No, just remember to connect ribbon cable the right way (B to A)
Thanks – my memory at fault!
Will do.
www.masterkeyboards.co.uk |
The order of cards which you were thinking was at the PCI times when there were different types. I think it was recommended to have core card first, process card(s) second and accell card(s) last.
Thank you – so many versions, so many years
Not so many, HD was introduced in 2002
#16
you might find some answers there : http://archive.digidesign.com/support/
if i recall well process cards had to be after accel's
My soundcloud page Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8 |
#17
Then came Accel. The cards needed to have first three DSP chips of the same original type. This was technical requirement for Mixer "plugin" compatibility. Accel cards had last six DSP chips of the newer and faster type. Then HD went PCI-express, and at that point all cards were Accel and just the same, with the same exception that core card had extra capacitor and different sticker. Now that we have HDX it is even simpler as there are no Core cards -- all are identical.
#18
i think i knew all this and i think i bought my first HD system in 2003
I was just pointing that using a magma chassis i had it this way all the time and nothing else would make it work. And even mabe in that order in the G4 Mirrored if no chassis I even remember some accels like Rev J or Rev G series (i forgot but had opened a thread at the time) were uncompatible with other accels http://akarchive.digidesign.com/supp...ms%20Guide.pdf (Page 9)
#19
Card order was very important prior to HD era.
HD made it less of an issue, because all of a sudden 6-card system fit into computer chassis of 3 slots and was slightly more powerful. Still some needed 6-card HD systems, and the external chassis of MIX era were not compatible and new ones were needed. Now maybe someone still needs 3-card HDX but most of us run our sessions happily without DSP cards.
Adding another Accel card ? | jackp | Pro Tools TDM Systems (Mac) | 8 | 10-28-2012 09:25 PM |
Adding an Accel Card Drama | Diggerthedogboy | Pro Tools TDM Systems (Win) | 2 | 11-11-2011 11:26 PM |
Adding another 888/24 and Accel card. Please advise. | ProTooler | Pro Tools TDM Systems (Mac) | 11 | 02-15-2011 12:07 PM |
Adding another Accel card | Dusan | Pro Tools TDM Systems (Win) | 4 | 02-18-2010 04:05 PM |
Adding Accel Card to HD3 -Questions | Ed Kish | Pro Tools TDM Systems (Mac) | 6 | 11-18-2003 01:43 PM |
