  #21
Old 02-13-2020, 12:28 PM
Lynn Gräber Lynn Gräber is offline
Default Re: EUCON 20.1.0 Released
Yes. Updated firmware. Can you please confirm something for me? Current firmware after my update today says 20.1.4 . However, the release notes say to update to 20.2? Am I misreading that? 20.1.4 is as far as it'll let me go.
  #22
Old 02-13-2020, 12:36 PM
EddieJones's Avatar
Originally Posted by Lynn Gräber View Post
Yes. Updated firmware. Can you please confirm something for me? Current firmware after my update today says 20.1.4 . However, the release notes say to update to 20.2? Am I miss reading that? 20.1.4 is as far as it'll let me go.
Thats an error in the guide that should read 20.1 (I'll get it updated) thanks
Yes 20.1.4 is the right firmware. What DAW are you using and can you describe the issue/jerkiness, what kind of moves causes it etc. ?
  #23
Old 02-13-2020, 12:42 PM
BScout BScout is offline
Originally Posted by Meads View Post
That would explain it. And there's no way to put into the code to pick one if the same MAC address comes in on both?
I mean, EUControl sees the iPad. Once. It just doesn't connect.
Not really, as Eddie says this is standard IP protocol behaviour.
I don't know if this will help but in Apple System Preferences for Networking you can set "service order" (click down on gear and you'll see it)
Make sure that the Ethernet you are using for networking is stacked higher than your wifi (drag them into the order you want)
  #24
Old 02-13-2020, 12:59 PM
XJENSEN XJENSEN is offline
I'm having trouble with quite some Waves plugins. The parameters seem to be mapped out in different order and not all parameters are visible (anymore). Will verify with another rig still on the previous version as soon as I can.
  #25
Old 02-13-2020, 01:38 PM
Meads Meads is offline
I appreciate your input. I know about the order setting and I had already set it up the way you suggest.
So what I did now is disable Wifi, restart the iPad - then the connection worked. After that I reenabled Wifi.
If the connection is remembered, this might just work - as it did before.
Thanks again!
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
  #26
Old 02-13-2020, 02:36 PM
mattrixx mattrixx is offline
Looks like the Control App update has not yet rolled out in Australia.
So, until it does, we have a Version Mismatch with 20.1.0
EDIT - Deleting the app from the iPad and re-installing gets the correct version. (so it seems it's not auto updating).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
  #27
Old 02-13-2020, 02:56 PM
Wow Eddie, this looks to be a really solid update so far!! Thank you!!
Matt McKenzie-Smith
mattrixx.net
  #28
Old 02-15-2020, 02:23 AM
bartosz idzi bartosz idzi is offline
Hi Eddie,
I'm on iOS 13.3.1, Avid Control on iPhone SE and PT 2019.12
1. Automation mode soft keys are still not working (read,touch,latch)
2. Redesigned pan graphs for channels are even smaller now, and there's a huge empty space in between stereo panners, is this a good move really?
3. Soft keys bar is missing from the bottom, is there a way to put it back there?
Thank you
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
  #29
Old 02-15-2020, 07:45 AM
I will say, after working on this for a few days, stability is MUCH improved. Thanks Eddie and the team. Now lets just get a few of those glitches and features ironed out!
  #30
Old 02-15-2020, 12:03 PM
Ellis Beckwith Ellis Beckwith is offline
I don't recall this happening with the prior version of Eucon, but now whenever the App is on and I mouse click on a track or a clip, a fader pops up in the middle of the computer screen. If i turn off the App on my iPad this does not happen.
Also, when the app is on and I'm working with the mix window on the computer screen, after I've opened one plugin on a track that is in a group, plugin windows on any other tracks in that same group will open when I select a track. this does not happen for tracks that are not in groups, and it does not happen when the App is turned off.
Is it possible to roll back to the prior version of EUCON if I can't find another reason for these new behaviors?
Ellis Beckwith
iMac (mid 2011), Intel Core i5 2.5 GHz, 32GB; Samsung 500Gb SSD, PT 2019.5.0, Avid Control; M-Audio Oxygen 25, Faderport 1
EUCON 20.1.0 Released EddieJones Artist Series 2 03-03-2020 07:31 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
