Mixed sample rate on project. What do I do?
So I'm new to pro tools and trying to bring a project over from reaper. The drums were recorded with a digital 8 track at 44.1khz. Then (I did not know this at the time) The guitar and bass tracks were recording in Reaper directly at 48khz. I imported the drums into pro tolls and started to mix them, and when I try to bring in the bass and guitar it says theya re not the same sample rate and adjusts them to match. This makes them slower and out of time with the drums.
Is there any way around this? Any thoughts or ideas are appreciated. |
Re: Mixed sample rate on project. What do I do?
when you import the guitar & bass you need to convert them. obviously you did not.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
When you bring in the audio, there is an option to sample rate convert (Apply SRC.) Set the sample rate (which it should do by default) to the session's sample rate.
Do that. Page 407 of the manual
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Thanks. I see that but the box is greyed out and disabled. I can't select anything. Why is that?
You can't apply SRC if you're adding the file. You have to copy it instead.
Ahhh Ok I got it working now thanks for the help.
Different sample rate in a project | Bacek_NJ | Tips & Tricks | 7 | 11-28-2017 05:01 AM |
Mixed Sample Rate omf | Pirate Post | Post - Surround - Video | 1 | 01-27-2005 08:12 AM |
Mixed Sample rate OMFs | feakerboo | Post - Surround - Video | 4 | 09-05-2004 08:37 PM |
what sample rate for my project? | Bermaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-08-2004 06:49 PM |
Any way to deal with mixed sample rate omf? | Wheelieboy426 | Pro Tools TDM Systems (Mac) | 4 | 12-08-2003 11:04 AM |
