Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-02-2016, 05:34 AM
Terry Wetzel Terry Wetzel is offline
Default Copy settings, paste settings ?
Good morning. I learned a while ago that in order to reduce strain on CPU, when I EQ a track, If I go to Audio suite>EQ>7 band (or other), Then Copy settings (original EQ), Paste settings, (Audio suite 7 band), The EQ that was copied & pasted doesn't sound at all like the original! Why is this? Thanks.
Old 04-02-2016, 05:36 AM
Stig Eliassen's Avatar
Default Re: Copy settings, paste settings ?
Any other real-time plugins in the chain?
Old 04-02-2016, 04:00 PM
Thanks Stig. That depends. I usually do this to Eq 7band and I always place it in the last insert position.
Old 04-02-2016, 08:32 PM
cwsand's Avatar
cwsand cwsand is offline
If the eq is originally placed last, but you remove it and apply it via Audio Suite, then the eq is effectively first in the chain, which will very likely change the sound of the audio processed by the whole chain.
BTW, I'm not sure what version of Pro Tools you're using or what kind of computer you have, but you're probably not going to save a whole lot of cpu resources by printing the 7-band eq this way.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 04-02-2016, 11:38 PM
Chris is right. Inserts flow from top to bottom, so this could change things dramatically.
Old 04-03-2016, 05:22 AM
OK cwsand. I didn't understand that by converting the plugin,(jn this case EQ7) that I was effectively removing it from the chain and after converting to audio suite, it would then be placed first in the chain. (I picked that up from a Yoitube video and they said it required less CPU by doing it that way). By the way I'm using Pro tools 9 on Win 7,32 bit. Thanks.
Old 04-03-2016, 06:13 AM
Whatever you have on the timeline, like Audiosuited clips, would be BEFORE any inserted plugins on the track.
And, you're not converting a plugin. You're simply copying a setting, and applying it directly on the clip.
C24 copy/paste settings tamtamstudio ICON & C|24 4 05-01-2016 12:19 AM
Copy/paste plugins settings doesn't work on certain plugins yazoo Post - Surround - Video 0 08-04-2014 04:46 PM
Copy/Paste plugins settings between different plugins? Zacsyd Pro Tools 10 9 05-02-2012 07:26 AM
PT10+10.7.2: COPY+PASTE automation settings "not compatible ?" bennym macOS 6 04-04-2012 04:37 PM
copy mix settings jpbears1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-25-2007 01:06 PM
