Old 09-30-2015, 08:49 PM
ronjohn333 ronjohn333 is offline
Default SAVE COPY IN bounce file nor .mov copy saved
When using the Save copy in, no bounce file nor its contents with the .mov file was saved nor copied in. The quicktime file properties are as follows:
- Quicktime 22.8MB
- Dimensions: 720 x 480
- Codecs H.264, Timecode, Linear PCM
-Color Profile: SD (6-1-6)
- Duration 00:42
Has anybody bumped into this?
Old 10-01-2015, 12:46 AM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Default Re: SAVE COPY IN bounce file nor .mov copy saved
Well Im not sure exactly what you are running into but I do know this.
when I do ave copy in the BOUNCE folder and any files in there are NOT copied over.
the save copy in works on ONLY the audio files within the session itself - timeline and or region bin.
So I just have to remember to grab anything else from the original folder BEORE tossing it or whatever.
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
saved copy in >> cannot read session - why is it saved as alias file? [SOLVED] kindkind Pro Tools 10 4 01-30-2016 12:42 AM
Cannot Move PT 10 File to PT 8 HD with ''Save Copy In" orc macOS 0 09-14-2012 10:10 AM
'save a copy as' damaged a file - file repair advice? Artysan Pro Tools TDM Systems (Mac) 8 03-26-2011 06:14 PM
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
File-Save-Session-Copy-In character add DelSpiva Pro Tools TDM Systems (Mac) 1 03-13-2000 08:24 AM
