Old 04-26-2015, 06:50 PM
Voice Crafters Voice Crafters is offline
Default Error AAE 9173! Urghhh!!!
Hey all,
I'm running PT 11.3.1 on OSX 10.10.2.
Very often when I try to bounce audio to disk, I get an AAE 9173 (even though system usage is very low - e.g. 5% CPU and about 25-27% memory).
The bounce is stopped. If I hit playback again without restarting Pro Tools it is very hissy throughout. The only thing to do at that point is restart PT.
The only way I can bounce now is offline....
I have a feeling it has to do with the video engine because I can bounce in real-time when there's no video involved in the session.
Help anyone?
Cheers,
Mony
Voice Crafters
www.voicecrafters.com
Audio Buzz
https://www.audiobuzz.com
PT 2019.5
Interface - Focusrite Clarett 8Pre
Mac Mini Running OSX 10.13.5
3.1 GHz Intel Core i7
16 GB 1600 MHz DDR3 RAM
External 4TB OWC drive
Old 04-26-2015, 07:43 PM
Robiscoe Robiscoe is offline
Default Re: Error AAE 9173! Arghh!
Same things not happening for me as well-using PT 11.3.1 on Yosemite 10.10.3 with i7 quad processor-bounce only works when all plug-ins are disabled-tried a 6 track mix with only Dverb enabled-no luck, CPU error message after 3 minutes. I'm a newbie, but all the threads I look at seem to indicate a fairly complicated situation between users and Avid. Thoughts anyone?
Old 04-27-2015, 06:05 PM
Post Re: Error AAE 9173! Urghhh!!!
Is this happening when bouncing to QuickTime? If so, have you tried the same bounce again?
I have a ticket open with Avid, and Brandon M. within their support group remoted into my system last Friday night and we spent nearly 2 hours troubleshooting an AAE -9173 while bouncing to QuickTime. We came to the conclusion that it only happens on the first attempt to do a realtime bounce to QuickTime. If I attempted a second realtime bounce to QuickTime, it worked. Offline bounce to QuickTime always worked.
Old 04-28-2015, 12:11 PM
jes's Avatar
jes jes is offline
Default Re: Error AAE 9173! Urghhh!!!
I haven't been able to bounce to disk reliably since version 11.2.1, which I can't go back to now with OS X 10.10. Online bounces give the error 9173, offline, it just crashes with a crash log of gibberish. The computer has plenty of power and memory, this has been happening in every update since 11.2.1 (running, or trying to run 11.3.1 now)
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
Old 05-10-2015, 05:27 PM
This is happening when I bounce to disk AND to QuickTime....
Voice Crafters
Audio Buzz
PT 2019.5
Old 05-11-2015, 08:20 PM
notedmusic notedmusic is offline
This happens to me all the stinking time- bounce or no.
Why haven't they fixed this problem? The forums and others besides are littered with this issue.
Composer/Sound Designer
Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909
HD Omni/Thunderbolt Native
A bucketload of libraries
www.Reverbnation.com/jedediahjenk
www.soundcloud.com/jedediahjenk
notedmusic.wix.com/jedediahjenk
Old 05-17-2015, 12:52 PM
barneykeys barneykeys is offline
Default
Same error on Win 7 64bit systems. But not just getting the AAE-9173 on bounces... it shows up all throughout working with Pro Tools 11. As a matter of fact, I'll get the error with a file open, simple sitting idle if I wait a few minutes. It has been a major issue 'round here for a while: on different systems, with different interfaces, after removing all plugins, etc. We've rolled back versions, replaced video cards (from ATI to approved Nvidea cards just in case it was video related issue)... we've tried all the tips and tricks. Nada....
We can't use Pro Tools 11 to record tracks without encountering stutters or the dreaded 9173 error. For the first time we are looking into different platforms and DAWs but would so love for Pro Tools to fix this stuff so we can dance with the one that brought us.
Win 7 Pro
3.4 i7
16 gb mem
Old 06-02-2015, 01:39 PM
GuyPicks GuyPicks is offline
Default
same here...pain in the ain.
I guess we'll have to pay to get it fixed.
My System
Mac mini M1
OS X 11.6.4
PreSonus 1824c
Faderport 16
Pro Tools Ultimate 2021.12
Studio One 6.5 Pro
Logic Pro X
Old 06-02-2015, 01:59 PM
john1192 john1192 is offline
Default
once your system goes "Hissy" .. just toggle the buffer settings in playback engine .. and you might want to up the buffers when bouncing .. does this only happen on Realtime Bounce or Offline as well ???
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-12-2015, 12:28 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Just a thought,... but I had 2 9173 errors when bouncing to disk when the file type was aiff..
just re did the bounce as wav and everything worked.
could this be a link to the issue since some have it and other don't and no where have I ran across the bounce file type mentioned EXCEPT for quicktime
thoughts???
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Pro Tools 11.1.0 AAE-9173 Error justus1900 Pro Tools 11 4 12-22-2015 02:46 PM
Error -9173 music.m Pro Tools 11 1 03-19-2015 09:42 AM
11.2.1 My Findings, -9173 error with BTD Intransit Pro Tools 11 77 11-23-2014 04:12 PM
PT 11 Clearly Not An AAE 9173 Error rgconrad1 Pro Tools 11 3 09-29-2014 11:56 PM
9173 error when bouncing se.audio macOS 3 09-09-2014 05:35 AM
