Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-21-2015, 06:53 PM
[email protected] 2009bfa3@gmail.com is offline
Default Mbox 2 mini play distorted sound
I use Pro Tools 11 and Mbox 2 mini
It's running on New Mac Book Pro i7 and OS 10.9.5
Problem
Audio playback normal change to distorted sound
Back to normal once you disable and enable playback engine 'Mbox 2 mini" again, but It will distorted again after couples minutes
Beside Pro Tools operation, I used Mbox2 mini as output interface for playback song from ITUNE also had same problem
I wonder it's not enough buffer for USB-audio playback?
Trouble Shooting
I tried following already
- updated Pro Tools 11 version
- set H/W buffer to max 1024
- install latest Mbox 2 mini driver
- turn off bluetooth and WiFi connection
- Directly plug into Mac Book Pro USB port
Anyone can help..? Please!!!!
Old 04-23-2015, 07:08 PM
guatamas guatamas is offline
Default Re: Mbox 2 mini play distorted sound
Problem
Trouble Shooting
USB 3.0 is your issue. You will need a powered USB 2.0 hub plugged into your MacBook Pro to stop distortion playback. Known issue here on the DUC as I have also had this issue with a late 2012 MacBook Pro and 2012 MAc Mini (Both USB 3.0 ports) with my Mbox 2.
For some reason the USB 3.0 ports are not and will not be compatible (AVID won't release new drivers for "semi-legacy" hardware)
Old 04-28-2015, 06:02 PM
U mean buy USB2.0 hub can fix problem?
MBox2 mini insert to hub only?
If i want to buy new USB interface, any suggestions?
How about Focusrite Scarlett USB interface?
Old 04-29-2015, 08:22 AM
In most cases, yes. A POWERED USB 2.0 hub can fix the issue.
I hear good things about the Focusrite stuff. Almost any USB interface will work with Pro Tools. ALMOST ANY<-----------
With any purchase you make, its always a good idea to do some research before you buy. Ask around the forums here for a recommended interface if you're unsure.
In any case, if you want to stick with AVID interfaces (For whatever reason). The Mbox 3 seems to be far more stable with USB 3.0. I got one used on Ebay for $130 US. The short time I have been testing it, it's doing well
Mbox2 mini - distorted sound in all programs greatFox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-19-2012 02:59 AM
MBOX Mini 3 Distorted Output coopere905 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-15-2012 12:51 AM
MBOX 2 MINI distorted and distortion problems Dennisclatham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-06-2012 08:10 PM
vocals sound distorted on record but play back fine dougbiggs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-06-2010 10:32 PM
Mbox Mini Distorted output problem paddy303 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-27-2009 01:45 PM
