Old 11-06-2014, 08:42 PM
jgagne1 jgagne1 is offline
Default Global Midi offset also changes the timing of the click?
Is there a way to use global midi offset without ALSO moving the click? For example, if your midi is latent and you set the midi offset to -500, then midi will play -500, but the click with moves. So if you have audio that already WAS on the grid, now it is not in sync with the click, which is playing 500 samples before it.
Is there a way to offset all of the midi without offsetting the click track?
midi global offset - midi click - delay compensation - VEPRO hanstondo Pro Tools 10 3 06-24-2020 05:17 PM
Global Midi Offset not working JohnnyFiction Pro Tools 11 3 12-16-2013 07:58 PM
Global Midi Offset puzzle... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-22-2003 11:54 PM
Click and Global MIDI Offset ajs Pro Tools TDM Systems (Mac) 0 05-04-2003 07:28 AM
Global Midi Offset J J Macrae MIDI 0 02-13-2003 01:57 PM
