Old 11-06-2013, 11:08 PM
gonzokarate gonzokarate is offline
Default Need Help Setting up My Firestudio to Record in ProTools
Please HELP!!
I purchased a PreSonus FireStudio Project about 4 years ago in order to be able to track drums. I did this by using GarageBand. Now I have Pro Tools 10 and want to use this hardware to track drums directly into ProTools. The problem is I have no idea how to set this up.
The Firestudio connects via Firewire to the back of my computer. When I turn it on the blue light on the front of the Firestudio becomes stable (indicating the it is recognized by the computer?). I then go into Pro Tools and have no idea what I need to do to continue on with the setup to allow me to get signal through the FireStudio, into ProTools, and recorded onto a track. I assume there is something within ProTools that I need to select and make it so Pro Tools recognizes the FireStudio??? Then maybe some type of I/O setup??? I am in waaay over my head and would be so grateful for any helpful hints or walkthroughs. Thanks so much for your time.
Old 11-07-2013, 12:17 AM
sunburst79 sunburst79 is offline
Default Re: Need Help Setting up My Firestudio to Record in ProTools
I would head over to Presonus and download the manual and latest driver. Once the driver is installed you should see the FireStudio listed as a hardware choice in PTs hardware setup window. If your not seeing the Firestudio as a hardware choice try launching PT while holding down the N key. If the drivers are correctly installed it will be listed. Once the driver is installed and its selected as your interface in PT you should see it in the IO section of PT.
See the "Help US Help You" link at the top of the forum if that doesn't get you up an running,
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-08-2013, 03:19 AM
All this and get a decent 3rd party book on using PT - there's several and for a total noob in PT the PT101 course book is a good one.
And most important - read the PT manual!
Jack
QAPLA!
Setting up two firestudio projects with protools 10 luay Third Party Interfaces 1 10-17-2013 06:24 AM
Need some help setting up ProTools to record with Eleven Rack thrashmetl Eleven Rack 19 08-11-2013 11:11 AM
Any ProTools 10 & Presonus Firestudio Users? Clemens Becker macOS 10 12-16-2012 10:54 PM
Will ProTools MP9 work with Presonus Firestudio? j99 macOS 5 10-26-2011 03:51 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
