#141
Re: Proper Recording Levels
Whatever volume (83db, 80dB, 77dB) you feel comfortable mixing for longer periods of time. You know your levels are little too low if some of your most loved CD's don't sound right. You know your levels are little too high if after 8 hours you're not satisfied with anything you hear.
Listening fatigue can though come a lot earlier. For example, you have a good vibe in the morning, but after lunch you begin to tweak everything and adding plugins here and there. That's the time to stop and let your ears rest, and to drop a dB. The whole point in calibrating speakers is that you always use same volume to mix your stuff. It is very easy to be fooled by the "louder = better" phenomenon. Your monitors may some day be 77dB and some other day 85dB and usually all over in between. How do you make good decisions if you don't know where you are? It really pays off in the long run.
#142
Well said JFreak.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
#143
Okay I'm still confused about one thing. Do both k20 and k14 have to be the same level of SPL? or do I need a different setting? For example does k20 need to be 79db SPL while k14 needs to be lower? Also if I may add where does the master volume need to be on my Mbox 2? Does it matter where I have it as long as I don't touch it again? Can I have it all the way up and calibrate that way?
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 Last edited by bryced87; 12-23-2013 at 09:43 AM. Reason: Additional info |
#144
The different metering (K14 and K20, for example, only define dynamics that you are targeting. Say you use K14 metering, that means the meter says "0" when you're 14 dB below full scale. And if your material RMS is hitting zero on the K14 meter while peaks are hitting zero on full scale meter, then you have 14dB peak-to-RMS ratio, a.k.a. dynamics. But you should listen to same volume whether you're mixing 20dB dynamics or 14dB dynamics or (God forbid) 8dB dynamics.
#145
Thanks I will do it again
#146
I love this place.
#147
Yeah me too - I have learned a lot about many things here - lots of people who earn their daily bread by audio (I don't but I wouldn't mind )
But I thanks them all for their help and patience
#148
I am still confused as to why Paul always keeps trimming the audio back to -10? This makes no sense to me because the input level would be way to low when he would bounce the song. Aren't you supposed to move the faders when you mix?
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
#149
OKay, I called him Kenny I meant Paul. Even when he changes the volume with a plugin he then trims what he changed back to -10
#150
The -10 is pre-fader ... Doesn't matter where the fader is ... You don't mix with TRIM plugins, you mix with faders.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA "It's not the gear ... it's the ear" |
Question on proper levels | LongRoad | Tips & Tricks | 11 | 06-14-2009 03:56 AM |
rca recording levels/proper interface channel | rygar22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2005 12:21 AM |
Recording Levels | jawjam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-20-2004 01:32 AM |
Proper recording/monitoring of vocals | MarkH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 08-16-2004 11:15 PM |
*Recording Levels* | mentalmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-03-2002 09:10 AM |
