Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 06-07-2013, 04:37 PM
62caster 62caster is offline
Default Help with new Mbox 3 Mini
Hello,
I recently got my Mbox 3 Mini hooked up, and noticed I'm running into the same problem as many others. When the mix knob is turned all the way to the left, I can only hear my guitar coming through out of one speaker.
Some details:
1. I am using a mono track, not stereo.
2. There is a 1/8 to 1/4 adapter on my headphones, but it is stereo.
3. I am going direct out of my POD into the Mbox line 1.
I emailed Avid support, and they gave me the basic recording instructions (create a mono track, adjust mix level, mute track, then record, etc) but haven't gotten back to me yet about the issue of audio only coming through one ear when i have the mix turned hard left. This used to happen on my old mbox, but I had a mono button I was able to press to fix it.
Is it possible to fix this?
Using OSX 10.7, Macbook Pro i5 2.4ghz, Pro Tools Express
Old 06-07-2013, 06:26 PM
browniespeaks browniespeaks is offline
Default Re: Help with new Mbox 3 Mini
There are work arounds involving adapters and other such stuff but no, there is no mix knob. No way to fix it, just a design flaw.
Sent from my SCH-I800 using Tapatalk 2
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 06-07-2013, 09:47 PM
That's really disappointing to hear. So I'm pretty much stuck hearing myself record through one ear?
I've tried un-muting the track I'm recording with and placing the mix knob in the middle, but the latency delay between the dry signal in the left ear, and signal coming from pro tools in the right is too much.
I've also tried un-muting and putting the mix knob hard right so all I hear is the PT signal, but the latency is again too much.
Any other thoughts/opinions/specific work around solutions?
Old 06-07-2013, 10:17 PM
Not sure exactly what Model Pod you have.
So the obvious thing is to run the Pod output L to the Mbox 01 input and R to 02. On a Pod you just need two TRS-TRS or TS-TS cables. That at least gives you a stereo direct hardware monitoring path. Make a stereo track if you want in Pro Tools.
Since you are already on headphoes while you are playing/tracking can you monitor from the Pod? or is here a backing or click track you are trying to play to? Use open headphones so you can hear that from your monitors while hearing the guitar in the headphones. Just get the levels set first and then monitor from the Pod.
Darryl
Old 06-07-2013, 10:20 PM
Other advice is sell the lot and get an Eleven Rack....
Darryl
Old 09-20-2013, 06:43 PM
Hey all, just circling back on this in case anybody else runs into it. I sent the Mbox back to Avid and got a replacement - issue solved!
Old 10-08-2013, 12:49 PM
negation negation is offline
Ok, cool, but I must ask: how did another mbox mini unit solve the problem with the nonexistent "mono-button-function" (as it worked with the original mbox 1gen)? I also own a mbox3 mini and I use the regular workaround (monitor direct sound in stereo).
PT 8.1cs1 HD2 Accel
10.6.4 MacPro 8 Core
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:29 PM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 12:58 PM
Mac Mini and Mbox 2 Mini Issues neilwilsonvoiceovers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-17-2010 09:34 AM
Please compare original mbox to mbox mini... mbart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2009 12:04 PM
Quality Dropoff from Digi 003 to Mbox or Mbox 2 Mini? Steve7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2008 02:10 PM
