Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 04-14-2013, 05:24 AM
adam79's Avatar
adam79 adam79 is offline
Default MBox 2 Issues - Firmware
I'm having connectivity issues w/ my MBox 2 and PT 8.0.5 LE. I'm running it on Snow Leopard 10.6.8. I've tried almost everything except changing the firmware. I currently have 1.43 and want to try and downgrade back to 1.38. Does anyone know how to do this? Thanks.
Old 04-14-2013, 01:35 PM
Felix Rost Felix Rost is offline
Default Re: MBox 2 Issues - Firmware
Did you try running the 1.38 Firmware Updater?
http://felixrost.de
Old 04-14-2013, 01:38 PM
adam79's Avatar
Yeah. It tells me that I already have 1.43 installed.
Old 04-14-2013, 01:43 PM
Try reinstalling the driver.
The USB cable is also a usual suspect.
http://felixrost.de
Old 04-14-2013, 02:01 PM
adam79's Avatar
I've tried both drivers that are on the Avid site, 10.3.3 and 9.0 with no luck. Also tried different cables and all the USB ports. Is there a place that show the driver information? The only spot that I've found is the System Preferences, which just notes the firmware; the Audio Midi Driver app gives the same info.
Old 04-14-2013, 05:53 PM
adam79's Avatar
In the Audio Midi Setup should it be listing both a Digi CoreAudio Device as well as the Digidesign MBox 2? Also, when opening the CoreAudio Manager, the Status is Not Connected (HW not found). When I click the Connect button nothing happens.
Old 04-15-2013, 04:40 AM
adam79's Avatar
Also, in System Preferences, it shows the MBox 2, but it says that it has 0in / 0out. So it's being recognized, but there's an error in the communication. This is driving me off the wall!
Firmware Issues BIG CHAT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-04-2012 06:29 AM
Firmware install issues SimonBarSinister Eleven Rack 6 03-22-2011 07:32 PM
Firmware issues on MC Control? chris_s_p Artist Series 2 02-21-2011 09:58 PM
Firmware Issues ocelot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-16-2008 08:13 AM
Firmware issues Xone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-09-2005 09:17 AM
