Old 05-16-2011, 05:13 AM
acmost acmost is offline
Default Basic Gain Structure Fader/Master Fader Question
So PTHD...
Say all my tracks in a session are kinda low, say -20db at the peaks. If I raise Individual Faders and or the Master Fader above what Pro Tools calls 0db on the Mixer...am I doing something undesirable in terms of Pro Tools Gain Structure efficiency? I mean it's all relative to each other somehow. If it's not clipping it's not clipping right, regardless of what the numbers say on the Pro Tools Mixer?
Old 05-16-2011, 05:36 AM
reichman's Avatar
reichman reichman is offline
Default Re: Basic Gain Structure Fader/Master Fader Question
Right. Don't worry about the value of the fader. Raise those individual tracks as high as you want, but watch the bus or master fader to see if the sum of all those tracks are clipping there. And... use your ears!
Does the master fader in pt produce additional parallel gain? illution1 Pro Tools 10 8 02-03-2014 02:33 PM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
SHOULD THE MASTER FADER ALWAYS STAY AT UNITY GAIN? michaux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 50 11-09-2003 11:31 PM
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? Ricky Cobble Pro Tools TDM Systems (Mac) 5 05-05-2003 04:47 AM
Using gain on master fader plug-ins to boost overall level? flymax Tips & Tricks 1 04-16-2001 03:05 PM
