Old 11-18-2008, 01:12 PM
Nils Groth Nils Groth is offline
Default Setup question
Hello,
I have a 192 and a Control 24 (the old one). Both pieces of hardware are connected with a DB 25 connector (192 audio out to control-24 audio in).
I am only doing stereo mixes. But because of the DB25, I am waste audio outs that I could use for external gear.
Can someone tell me if there is a procedure/config to do on control 24 so that I can start using the "wasted audio outs" ?
Regards, Nils.
Old 11-18-2008, 01:25 PM
Shawn Simpson Shawn Simpson is offline
Default Re: Setup question
Just wire up a DB25-MXLR cable to go from your 192 and a DB25-FXLR to connect to the main inputs of the Control|24, then connect outputs 1 and 2 to the Main L-R input that you'd want to use. You'll have the other 6 channels there on MXLR to connect to anything you'd like. You can buy those cables pre-made for about $100US each or build them yourself for about $30US each.
Another option would be to wire your gear up to a patchbay so that you'll have the flexibility to connect your studio however you need it to be.
Old 11-18-2008, 07:22 PM
Thanks Shawn,
I was hoping there was a way to not do any cable surgery -
Cheers, Nils.
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Setup question JNS Pro Tools TDM Systems (Mac) 3 03-02-2010 11:19 AM
Setup Question drebeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-28-2009 09:29 AM
setup question gira29 MIDI 1 02-22-2003 05:35 PM
002 Setup Question wanderingstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-06-2002 09:06 AM
