Old 09-09-2006, 03:19 AM
Surth Surth is offline
Default Ableton Live - performing/recording live w/HD3
I am trying to record 'live' Ableton Live performances while Rewired into ProTools (7.1). I need to be able to adjust the tempo on the fly during the performance. If I put PT in manual tempo mode it will sort of try to follow the tempo changes but the audio is momentarily interupted & Live's MIDI mapping for the tempo setting will no longer work (or the manual tap). Changing the audio w/ the PT transport has the same effect. I would like to have the PT beat clock follow the clock from Live, but apparently it is not capable of doing this for some reason. Can anyone tell me if there is any workaround to this problem? As an alternative, is there a way for the Live clock to function independently from the PT beat clock? I understand that Live is functioning as a Rewire slave in this situation, but the inability of the PT beat clock to allow Live to alter the tempo seems to defeat much of the purpose of having a 'live' performance tool. Someone please tell me I'm missing something here! Thanks.
Old 09-11-2006, 04:50 AM
PastaViking II PastaViking II is offline
Default Re: Ableton Live - performing/recording live w/HD3
Unfortunately, I believe PT handles all the tempo changes when Live is in Rewire slave mode. If I had to suggest a workaroud it would be to use Core Audio instead of Rewire and send audio into PT that way (with a cable). Start Live first to disable it as Rewire Slave (you need the full version to do this). Then slave PT to Live's tempo via the IAC bus.
Hope you get the idea - I haven't tested it myself...
playing live, ableton live best option? shabbar3 Pro Tools 9 0 07-11-2013 05:22 PM
Performing Live philadesigns Virtual Instruments 0 03-04-2009 03:18 PM
Recording into Pro Tools from Ableton Live siggy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-20-2005 07:46 PM
Recording w/Ableton Live slangification Pro Tools TDM Systems (Mac) 5 07-01-2004 09:24 AM
Recording Ableton Live in loop mode? wizdoom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2004 08:45 PM
