Old 01-04-2000, 10:04 AM
JKD99 JKD99 is offline
Default HUI Fighting Faders
Hi all
I have a recurring problem with the HUI in that, regardless of what auto mode I'm in, the faders will sometimes resist being moved ( I can feel them trying to return to the previous level even in write mode). As a result, at best I end up with a zillion little up-down auto breakpoints. At worst, I have to redo the pass for that section. Any clues? Thanks and Happy New Year!
Joe Milner
Puget Sound
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 01-04-2000, 10:54 AM
blairl blairl is offline
Default Re: HUI Fighting Faders
I don't want to get you depressed or anything, but this topic has been thoroughly discussed on other posts.
Click here to see the bad news:
http://www.digidesign.com/ubb/Forum27/HTML/001605.html
AND:
www.digidesign.com/ubb/Forum27/HTML/001742.html
I was able to use the sensitivity screws located on the underside of the console to help with my problem. There are two rows of screws. The row you need to work with is the row with the staggered screw. (The staggered screw is the 8th fader). Depending on which faders are fighting you can turn the screws counterclockwise to reduce the resistance on that channel. Be careful, because if you do it too much that fader will move when your finger even gets close to it without touching it.
Good Luck!
[This message has been edited by blairl (edited January 04, 2000).]
Old 01-04-2000, 11:50 AM
thanks Blair. I'll check it out!
Joe Milner
Puget Sound
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Old 01-05-2000, 12:23 AM
My God, what a saga. Ray Fabi, Phil Buckle, TMS, MLocascio, Blair...a very sad tale to read all those posts at once. Sorry to bring up bad memories.Thanks for the info guys; the Pro Control is looking better all the time.......
Joe Milner
Puget Sound
[This message has been edited by JKD99 (edited January 04, 2000).]
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Old 01-05-2000, 10:34 AM
Garry Garry is offline
Joe,
I posted this to the topic you probably read, but just in case you missed it: Try running a heavy copper wire (Monster Cable works well) from a cover screw at the bottom of the HUI (one of the perimeter screws that go into the chassis) to a good ground source, like a copper water pipe or any other direct ground connection. This solved the problem for me.
Good Luck,
Garry
fighting faders Will Russell ICON & C|24 51 01-12-2018 06:14 PM
Faders fighting back remainanon ProControl, Control|24, Command|8 8 06-02-2009 02:46 PM
Fighting faders on a 002 console kidbazooka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-09-2008 07:48 AM
Fighting faders PTGuy ICON & C|24 27 02-18-2008 06:09 AM
Fighting faders? nettwerk ICON & C|24 6 10-15-2002 02:38 PM
