Old 02-23-2005, 08:34 PM
MorphedProd MorphedProd is offline
Default adding inputs to 002R
I'm trying to make a good decision without spending another 2 grand on PT hardware. I need more inputs and outboard FX. The Yamaha 01x is pretty well priced and full controller with inputs and an internal FX section to minimize load on PC, plus control surface. Can anyone tell me if it will be compatible; will it add inputs to my 002R setup within PT software?
Old 02-23-2005, 08:49 PM
macr0w macr0w is offline
Default Re: adding inputs to 002R
I think you would do better to get a Presonus digimax and a Command/8. The digimax would give you 8 more i/o and the C/8 would give you a good control surface. I'm not sure the yami unit would give you what you need. I think it does m-lan or firewire. Is it just a control surface? Anyway you need adat or s/pdif inputs for your 002R. Do a seach on digimax or adat and you'll find lots of talk about them and others. Check this baby out. I wish I would have seen this before I got the digimax. Lots of options.
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
www.clearspotrecording.com
Old 02-23-2005, 09:04 PM
cool, thanks for you help. well at those kind of prices and the fact that i'd still need extra outboard FX units, can't i just add a 002 console? will the 002 FX function while NOT in standalone mode?
Adding Inputs to the 002r drassmantis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-03-2007 05:17 PM
Adding four more inputs WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-29-2006 10:03 AM
Adding more inputs with the 002 time808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-14-2005 02:58 PM
adding inputs to M-Box mastershredder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2005 09:14 PM
Adding audio inputs to a 001 set up. Symetrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-24-2004 07:08 AM
