Old 08-24-2004, 12:08 PM
jzucker jzucker is offline
Default Can\'t get 002 WDM driver to work
Running on XP SP 1, I can't get the system to recognize the WDM drivers (wave / direct sound).
The ASIO drivers work fine in pro tools and Sonar but I can't select them as a playback device in windows.
I've talked 3x to Digi tech support with no luck. At this point, I've installed 6.1.2, updated to 6.4, manually deleted all drivers and uninstalled everything, repeated the entire installation, etc.
Playback and recording work great through ASIO but WDM is not being recognized.
Old 08-24-2004, 01:12 PM
Default Re: Can\'t get 002 WDM driver to work
bump...
Old 08-24-2004, 01:30 PM
lemix's Avatar
lemix lemix is offline
jzucker ,
Drivers for third party apps have been covered here too many times...try the search.
>the Digi ASIO driver is not needed at all to run PT LE. I don't think you select it in windows for the apps that support it BTW. The application itself has to select it. Besides, not all third party software support ASIO. You might try the Digidesign wavedriver...again, please search,
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 08-24-2004, 02:23 PM
I don't consider the standard windows playback device to be a 3rd party app. I did a search and found nothing. Any suggestions on a search string?
WDM yields little. WAVE returns a bunch of unrelated stuff...
Old 08-24-2004, 03:02 PM
lemix's Avatar
"Windows Driver Model" , aka WDM has nothing to do with Protools , and as a matter of fact I do not think it is at all related to Windows XP.
What is your problem exactly ?
If you are planning to play audio out through the Digi hardware, only the wavedriver and the ASIO driver supplied by Digidesign will work.
..hope this helps...
cheers,
Andrew
Old 08-24-2004, 03:25 PM
It's the wave driver I'm talking about. It doesn't show up in the audio dialog. (Read the original posting)
Old 08-24-2004, 04:08 PM
spkguitar's Avatar
Have you tried reinstalling JUST the wavedriver?
The ASIO driver gets installed by default, but if I remember correctly, I think the wavedriver needs to be installed separately. (It's been so long since I've done it, I forget)
Old 08-24-2004, 04:12 PM
Yep. That's the first thing I tried. No go.
Jaz
Old 08-24-2004, 04:14 PM
List all the apps in MME Helper on your system.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-24-2004, 04:26 PM
I posted a jpg of the app's window at www.sheetsofsound.net/mmehelper.jpg
However, I don't see what this has to do with the issue. The issue is that the digi-002 does not appear as an option in the Sounds and Audio Devices property sheet on the Audio Tab's default device combo box. If it doesn't show up there, the apps that are listed in mmehelper are irrelevant.
Will 10.5.1 driver work with 10.5.2 OS ? driver49 Pro Tools M-Powered (Mac) 0 03-09-2008 11:31 AM
Coreaudio driver won't work Hanslemonverm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-30-2006 06:59 PM
Wave Driver doesn't seem to work at all... GiantMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-21-2004 03:06 PM
Can't get the ASIO driver to work... Rammelt Pro Tools TDM Systems (Win) 8 10-30-2003 05:03 PM
6.1.1 CoreAudio Driver does it work for you? Mark Wheaton Pro Tools TDM Systems (Mac) 1 09-23-2003 04:56 PM
