Old 04-22-2004, 12:06 PM
wolfman wolfman is offline
Default Prefs: Global MIDI Playback Offset....Question....
My ProTools engine runs at 128 samples, Sampletank Free induces a latency of 64 samples, so I´ve got 192 samples delay/offset to the audio click. When I then set the -192 samples under Windows>MIDI Track Offsets for the specific track the delay "compensation" works perfectly! BUT when I try to achieve this with the Global Midi Playback Parameter under Prefs, there´s absolutely no change (also tested with ridicolous 10000samples - no change!).
Now is this a known bug - or is this paramter meant to be for something else? Running 6.4 here.
Old 04-22-2004, 01:16 PM
Roy Howell Roy Howell is offline
Default Re: Prefs: Global MIDI Playback Offset....Question....
wolfman,
Have you tried it with 'Low Latency Monitoring' off? (Global Midi offset that is).
rh music
Old 04-22-2004, 03:20 PM
Hi Roy,
yes I tried both (on/off) with no noticeable difference: Setting the individual track offset works but not the global offset.
Is there maybe some other parameter that has an influence on the global midi offset functionality?
Ken.
Old 01-17-2005, 10:47 PM
phobia phobia is offline
Did you get this sorted out?
/ P
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
Old 01-18-2005, 09:24 AM
myfm myfm is offline
Global MIDI Offset sets the offset at the midi interface. It will only affect hardware you have hooked up to the midi interface.
The individual midi track offset affects an individual midi track. Since you're using softsynths that do not go through the midi interface, the Global Midi Offset would have no effect on softsynths.
"Global MIDI Offset" value in preferences Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-18-2007 09:59 AM
Global Midi Offset puzzle... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-22-2003 11:54 PM
Click and Global MIDI Offset ajs Pro Tools TDM Systems (Mac) 0 05-04-2003 07:28 AM
Global midi offset problem agock MIDI 0 02-16-2003 09:37 PM
Global Midi Offset J J Macrae MIDI 0 02-13-2003 01:57 PM
