Old 01-15-2021, 04:44 PM
Sonopolis Sonopolis is offline
Default 32bit SRC bug
When I import a 32bit file and use sampling rate conversion the resulting file is wrong.
When I import it with 4.1667% pull up (50kHz) it results in a file playing much too fast and Mickey Mousey high. The resulting file is precisely 1/4 the length of the original. When importing it with 0.1% pull up the result is actually longer than the original. I have not tested all options so it’s possible there are problems with other SRC settings, too.
Can somebody confirm this, please? Reimporting a simple 32bit sine tone with these SRC settings should give the same result.
This is on Mojave with 2020.12 Ultimate
Old 01-15-2021, 10:59 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: 32bit SRC bug
Bit Depth/Sample Rate - 2 different things.
Exactly as it should be. If you check Apply SRC in the Import Audio window and using that drop down box to select a custom sample rate, keep in mind you're telling Pro Tools that the Source sample rate is different than what the source file actually is. Pro Tools treats the file as being at the sample rate you selected and converts it to the sample rate of the session. As a result, the file length and pitch will change if you selected a source sample rate other than what the original file was. Again, this is converting the sample rate, not changing the bit depth.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-15-2021, 11:10 PM
Sardi Sardi is offline
Bit depth not bit rate.
Old 01-16-2021, 12:24 AM
cwsand's Avatar
Right!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-16-2021, 09:23 AM
Pete Gates Pete Gates is offline
No it's not exactly as it should be. Sonopolis is right, if you go to "48KHz (pull up/down)" and select either 50,050 or 50,000 then look at what Pro Tools puts as the source sample rate... It's a bug.
Cheers,
Pete
Old 01-16-2021, 09:34 AM
Ok, so you're all assuming the error is in the user, great.
To clear things up, I am very well aware of the difference in sampling rate and bit depth. What I'm saying is that the this sampling rate conversion error only happens with files that have a bit depth of 32.
No, not exactly how it should be. I am also aware of how sampling rate conversion in Pro Tools works. However the resulting file should not have exactly 1/4 the length of the original but instead be be 4.1667% shorter and playing higher. Wouldn't you agree?
Old 01-16-2021, 09:40 AM
Cheers,
Pete
Exactly. just realized this, too. So I stand corrected, 0.1 pull up works and not only 32 bit files are affected.
Old 01-16-2021, 10:15 PM
cwsand's Avatar
I don't know - last night when I tested the 2 settings you listed, the resulting files were exactly as they should have been, but I didn't test it any further. But when selecting any of the Pull Up/Pull Down presets now, some show the correct sample rate and some don't. It's bizarre because I still have the session and the file imported at 0.1% Up is only slightly faster than the original. It may be an intermittent problem.
I installed PT 2020.3.0 and all the Pull Up/Down settings show the correct source sample rate when selected so some of the settings in 2020.12.0 are showing up as the wrong sample rate. I'll report the bug and hopefully it gets fixed in the next release.
At least you can enter the correct sample rate manually as a workaround.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 01-17-2021, 03:08 AM
Like I said, 0.1% works, it's 50050 and 50000 that cause the problems.
Thanks for reporting, I did too.
Old 01-18-2021, 12:33 AM
cwsand's Avatar
Yes, the 50,050 that is 0.1% Up NTSC to PAL is messed up, but the 48,048 0.1% Up NTSC to Film is ok.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
32bit AAX vs RTAS Carl Kolchak AAX Plug-ins 14 04-30-2013 03:39 PM
32bit or 64bit?? Codo Pro Tools TDM Systems (Mac) 3 03-02-2012 03:14 AM
32bit Bounce? Numi Pro Tools 9 3 11-14-2010 12:18 PM
Windowsn 7 RC 32bit SteveGam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-31-2009 01:11 PM
going from 64bit to 32bit sterndrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 12-11-2008 10:12 AM
